JD 45 Loader - Questions
Grant Fluent
11-15-2004 19:24:50
I have a JD 45 loader mounted on a JD 50. The loader has the trip bucket and I would like to convert it to a hydraulic dump. I'm told John Deere made a kit for that. Does anyone have pictures or any information of that setup?
Thanks,
Grant Fluent
Newcastle, NE
Paul in Iowa
11-16-2004 18:16:48
 Re: JD 45 Loader - Questions in reply to Grant Fluent, 11-15-2004 19:24:50
Grant, I have a John Deere # 45 straight arm loader with a FACTORY hydraulic bucket on my John Deere 60. I have had it for many years and it works great. I also have a # 45W and some other trip bucket 45s as well and think they are great. As far as your plumbing question on your 50 you need a dual spool hydraulic valve that can be plumbed off your powertrol but BEWARE don't keep the lever ahead all the time or it will damage the hydraulic system since it will have to constantly bypass when you are not actually operating the loader. The best way is to actually connect into the hydaulic lines, pressure and return from the hydraulic pump.
F-I-T
11-17-2004 11:14:47
 Re: JD 45 Loader - Questions in reply to Paul in Iowa, 11-16-2004 18:16:48
Paul:
I run the oil from the Powr-Trol to the 2 spool valve, through the valve, and back to the Powr-Trol box. Lever stays forward all the time.It doesn't run through the Powr-TRol bypass....it's just circulating. The only time you would have uit bump up against the by-pass valve is if it was dead heading against a load. That doesan't happen, so no damage can occur.
I've done it that way for years.
Frank
F-I-T
11-16-2004 06:33:44
third party image
Grant:
Both the 45 and 45W ("W" meaning for wide front ends) were available with hydraulic dump options. If there was a kit, it's probably no longer available, but it would easy enough to fabricate by looking at the parts book.
Here's a few shots of my 45W with factory hydraulic bucket, though the bucket is not JD.
Frank-in-Tallahassee
�56 70D // �90 855 // �50 VAC // �48 Cub // Coming soon �a new addition!
[email protected]
Grant Fluent
11-16-2004 17:45:13
 Re: JD 45 Loader - Questions in reply to F-I-T, 11-16-2004 06:33:44
Thanks for the pictures Frank! How is your hydraulics plumbed? Do you run the Power-Trol lever ahead all of the time? I was trying to figure out if I should do that or use a selector valve to switch between the bucket and the lift cylinders?
F-I-T
11-17-2004 11:10:04
 Re: JD 45 Loader - Questions in reply to Grant Fluent, 11-16-2004 17:45:13
Grant:
Yes, I have the P-trol lever forward running through a two valve bank of open center valves, which operate the up/down, dump/return. If I forget and overload or hold the action for too long it will trip the P-trol lever, but I guess that's good.
This works pretty well for me.
Frank
I Bleed Green
11-16-2004 03:37:23
YES John Deere made a hydraulic dump attachment for the 45 and 45-W loaders. If you would like to see how it looks, E-mail me. I have the parts book, and brochure with picutres of it.
mike2
11-15-2004 21:52:29
Hi Grant, I have seen the loaders with the hyd. dump but they were called the 45w. I have three regualr loaders, if you need some parts possibly. I will do some asking around as well if they made a kit. I have a stanhoist that they did that with. Welded brackets to the arms to mount cylinders. I passed up a 45w, a few years ago and have kicked my butt ever since. Glad to see someone from the area on here. Mike Wakefield,NE
Grant Fluent
11-16-2004 17:53:20
 Re: JD 45 Loader - Questions in reply to mike2, 11-15-2004 21:52:29
Mike, Thanks for your reply fellow Nebraskan! The 45 loader I have is in great shape and still has most of the paint on it. I would just like to put a cylinder(s) on the bucket. Another guy on the forum sent me some info on the hyd dump parts. Now, if I can just figure out how the hydraulics was originally plumbed...
Grant Fluent
Newcastle, NE
Hayfarmer
11-15-2004 20:25:45
Take a look at an operator's manuel and parts book for the 45 I would think those would show it with trip or hydraulic bucket.
BillS
11-15-2004 22:05:36
 Re: JD 45 Loader - Questions in reply to Hayfarmer, 11-15-2004 20:25:45
I don't believe there was ever anything factory for a #45 hydraulic bucket. Any that I ever saw were farmer engineered. A #45W has the curved arms to go around the wide front and I am pretty sure thats the only difference and where the "W" comes in. They are alot less common than the regular #45s. I also have a #45 on a 50. If you were to put a hydraulic bucket on it how would you plumb the hydraulics? I have the problem of having to use either my loader or my aftermarket rockshaft operated 3 point. At the moment I have the loader on one 50 and the 3 point on another 50 but would someday like to incorporate both into one tractor so I could sell one tractor. I am sort of in the same neighborhood in western Iowa.
Arnie
11-16-2004 05:23:45
 Re: JD 45 Loader - Questions in reply to BillS, 11-15-2004 22:05:36
Bill if you ever get to the point of selling one of your 50s let me know might be interested and do you have any pics of them thanks for your time
BillS
11-16-2004 21:28:27
 Re: JD 45 Loader - Questions in reply to Arnie, 11-16-2004 05:23:45
Arnie, either e-mail me or let me know your e-amil address
