How do get this AR unstuck???
Neal
11-15-2004 09:17:11
I have a 1947 electric start AR that is stuck. I got this tractor about two years ago and have had Blaster in it for the duration. I pulled it out about a month ago and have put constant tension on the flywheel. I have taken the starter off and the top off to get to the connecting rods. But have still not gotten it to budge. I have also checked and I have two valves stuck open. I was going to use hydraulic pressure but with the valves stuck open, not an option.
Any suggestions? Thanks
donwisc
11-15-2004 19:53:12
 Re: How do get this AR unstuck??? in reply to Neal, 11-15-2004 09:17:11
I just freed up a unstyled A that was stuck for a couple years. The head was off so I made a plate out of hardwood that fit over 3 of the head bolts. I then put a short piece of 4x4 in the cyl up against the piston I thought was stuck and then used the head bolts as jack bolts.
Prior to this I had the front end up on car ramps so I could get more penetrating oil higher in the cylinder and soaking for a couple days.
I got the piston to move the second day and after moving the pistons back and forth a couple times it freed up so i Could turn the flywheel by hand.
I also put my propane heater under the block and turned it up full blast and its possible I got some expansion of the block which would help the penetrating oil.
Be patient and good luck
dbwillia
11-15-2004 15:15:02
A gentleman in an old car publication, stated he had a car that he tried to free with all kinds of solutions. An older mechanic told him to use one cup of plain dish washing soap in each cylinder. It took two days or less and he stated there were no negative results with the engine.
old
11-15-2004 10:36:45
I'd try some turpentine in the cylinders an let it sit a couple days. Mixed with the PB it should come loose if it is going to. also helps if you can raise the front end up so it covers more of the piston. Don't use paint thinner but the real turpentine. If that doesn't do it you will have to pull it apart.
Johan
11-15-2004 10:04:07
I would first take off the rocker arms so that the cam shaft can move freely. check that the oil pump is not stuck as well. I would try with a long lever chained to the flywheel. Rock genlty back and forth. If no good, loosen one con rod, maybe you can brake loose them one at a time, easier than both at once. Good luck.
Mike M
11-15-2004 09:34:37
If this tractor was sitting out for awhile before you bought it you more than likely have to pull the block out with the pistons in it stand it up than soak it and try driving them out one at a time with a block of wood and a sledge.
Harold O
11-15-2004 20:22:02
 Re: How do get this AR unstuck??? in reply to Mike M, 11-15-2004 09:34:37
Mike M has the best plan. your head has to come off anyway to seat the valves and then you will see why the engine is stuck. Harold. PS there is usualy enough crud in front of the piston so that you couldnt make a full turn anyway. Good luck
ira
11-15-2004 20:00:39
2parts brake fluid 1 part automatic trans. fluid. soak it good ket it stand for a day or two . tap the piston with a block of wood . just unstuck a cub that had set outside uncovered for three years.
