4020 electric
Ray Hudson
11-14-2004 14:15:10
former owner messed with wiring on 67 4020d now I dont have power to guages or lighes are guages 12or24 voltswhere do I start checking
buickanddeere
11-15-2004 08:33:03
 Re: 4020 electric in reply to Ray Hudson, 11-14-2004 14:15:10
24V Starter, regulator and generator use no electrical connections to chassis. Lights and instruments do. 1/2 positive ground and 1/2 are negative ground 12V lights and instruments. If 12V loads were perfectly ballanced no current even flows through the "ground wire" connected to the battery's mid point to chassis. The wire is to handle slight mismatches in proction tolerances and keeps the other light pair should it's mate blow out.
txblu
11-15-2004 09:52:18
 Re: 4020 electric in reply to buickanddeere, 11-15-2004 08:33:03
Totally agree with what you said and know that some have "the wire". Mine (battery chassis terminals) happen to be hard wired with 00 to the starter mounting screw and don't use it. Makes a convenient terminal. Guess if it was OEM, somewhere along the way some enterprising farmer must have wired it out of the ckt.
But maybe not, as I have 2 circuit breakers mounted at the starter; one for each ckt (light/inst. pnl. ckt, not starting ckt). So maybe it never was.
Mark
HTR
11-15-2004 18:06:16
 Re: 4020 electric in reply to txblu, 11-15-2004 09:52:18
Yours is the way it came from the factory, except they were braided wires bolted to the transmission cover. The cross over wire, with the common ground, and circuit breakers came as an add on change over. The usual problem was, on a foggy rainy night, a short to frame in the start/netural start circuit, would start the starter cranking, and if the throttle was down? and if the throttle was open, and it was in gear??
Due to the path of least resistance, I think, there will be current flowing through the common ground wire. For example, if you have the four fender lights on, and you lose the fuse in the wire to ground, the path of least resistance is lost. This makes the next path of least resistance through the filament of one of the light circuits to the fender to the filaments of other light circuit. This puts the lights in a twenty four volt series curcit. From experience, with twenty four volts through the lights, two of them, on one of the circuts burn brighter, and burn out. This breaks the series curcit. With the fuel guage and oil light on one of the circuits, and uneven heating of the filaments, I don't think you can achieve a perfectly balanced twenty four volt series curcuit on these tractors. That is the way it would have to be, if no current is flowing through the common ground wire.
txblu
11-15-2004 07:14:16
Besides what's said.
You have 2 ckts, A and B. A+B = starter, gen, VR, both batteries = 24 volts.
A ckt runs one side of tractor (+ ). B runs the other (- ) I could have which is A or B reversed as I am at work. The back of the ign sw is marked accordingly.
My instruments are on the B ckt.....the one that has the + lead of the battery grounded. Everything is 12v under the dash if it needs power. If you wire up your instruments using the wrong battery, instead of deflecting into the visable area, they will merely deflect back in the corner where they were at rest. This is not good and could harm things like your fuel gauge for one.
Lights are evenly split, half on one side (A ) and half on the other (B). You should measure your battery voltage with the tractor running and have an equal split (best fit) of the 24 volt output.
Read my thread a few down where Last Friday, I measured my 4010. Might have some pointers there.
Mark
Gerald J.
11-14-2004 16:34:20
All the lights and gauges are 12 volts. The center of the 24 volt system is grounded. Some lights and gauges are on positive, some are on negative. Only the starter and generator run at 24 volts.
The best reference is the Deere shop manual TM-2039 for that vintage 4020.
Gerald J.
msb
11-14-2004 17:31:17
 Re: 4020 electric in reply to Gerald J., 11-14-2004 16:34:20
First thing to check is the ground wire on the left side battery.There should be some sort of a small ground wire on the rear post going to the transmission case.You may find a fuse holder in the line.Check to see if it has blown the fuse.It takes a slow blow fuse.An ordinary wire will work quite well if the wire is missing,burned up or corroded etc.It doesn't really need a fuse but it is better if there is one in the line.
