JD 420 T
Tommy W Thomas
11-14-2004 13:21:00
Help,
I have a JD 420 that I can't get tocrank. I have replaced coil, condenser, point and rotor button, and plugs. I have fire at at the coil, distributor and fire at the points, also fire going to the plugs. It does have gas in the tank for those who think that I haven't check that. Anyone every have this sort of problem and what was to solution. I have check everything that I can think may be wrong.
Any help and advice would be welcome. I begining to rub my hair out.
Thanks
Tommy
Buffloman
11-14-2004 21:54:00
 Re: JD 420 T in reply to Tommy W Thomas, 11-14-2004 13:21:00
If you have spark to the plugs then you gas.That is the other half of the equation
Putting a little gas right in the air intake of the carb. If it kick over. Then you have a plugged gas line.
Wayne in Tn.
11-14-2004 16:35:20
Tommy it only takes two things for it to crank, fire and gas at the right times. First, was it running before doing the ignition work? If so, probably the timing and valves are ok. Next, if you have grounded the plugs and know they are firing, then probably it is not getting gas. Open the drain on the bottom of the carb. should be a good stream of gas running out, if not start checking for plugged filter at the carb. inlet, then the sediment bowl, remove the gas line from the bowl and open the valve, should have a good stream of gas here, if not maybe trash is plugging the outlet in the tank.
If it is not a gas problem, and it was running before, maybe the points or condenser are not getting a ground or not set correctly. Points set on .022
SB in AR
11-15-2004 06:25:12
 Re: JD 420 T in reply to Wayne in Tn., 11-14-2004 16:35:20
I'm not trying to be a smart a%$, but it actually takes THREE things for an engine to run. Fuel, Fire (Spark), and Air. Air is usually not a problem, and it is one of the hardest to check, but if all else fails, check to make sure your getting enough air.
Henry J
11-14-2004 15:17:21
Thomas
Have you gone through some steps to see if you are getting the gas into the carb? Just wondering, you did not mention that.
If you have geen cranking the dickens out of it, the plugs should be wet by now?
L.C.
11-14-2004 15:41:33
 Re: JD 420 T in reply to Henry J, 11-14-2004 15:17:21
I'll second Henry J's comments about checking the plugs to see if you're getting fuel to the cylinders.
Second, is the gas fresh? Old gas makes cranking a tractor more difficult. (And is the fuel cutoff valve under the tank open? I've occasionally forgot to open it, but remember when it quits about the time I drive out of the shed.)
Also, are you getting a strong spark?
My experience with my 420s is the points tend to be the culprit when it won't fire, especially after sitting.
