FOUND A BR
DENNIS IN NC
11-14-2004 05:33:56
I AM THINKING OF BUYING A 1936 BR CAN ANYONE TELL ME SOME THINGS I SHOULD LOOK HARD AT? I HAVE NEVER SEEN ANOTHER AND DON'T KNOW MUCH ABOUT THEM BUT IT'S A CUTE LITTLE TRACTOR
Kris A NC
11-15-2004 11:00:20
 Re: FOUND A BR in reply to DENNIS IN NC, 11-14-2004 05:33:56
Dennis, Where in NC are you located? If you are not interested or end up not buying the BR would you let me know. I might be interested. I love those tractors and would love to add one to my collection. Thanks and if you decide to get it let me know I would love to see a picture if possible. take care and good luck
Kris A NC
dennis in nc
11-15-2004 18:59:42
 Re: FOUND A BR in reply to Kris A NC, 11-15-2004 11:00:20
western nc lake lure near chimney rock or asheville/howbout you hay tell me about the brass tag????? ?????
dennis in nc
11-15-2004 18:58:09
JD4boltB
11-14-2004 13:26:21
dennis, a BR is a nice tractor for a person just getting into the hobby. i am not sure of the condition of this tractor but it sounds like you found it outside somewhere, either on a farm or in the woods. you need to check the bottom of the block to see if it is cracked. also check the bottom of the head for cracks along with the radiator as well. some farmers would abandon these machines when they bought a newer one and might leave water in the engine, which would freeze and cause all kinds of trouble. or the water would somehow get into the engine and acculate to the point of being able to freeze, etc. of course, by checking for these problems, you will only see the external trouble this way and will not know the true extent of the damage until you tear it all down. gives you an idea though what to expect if you see the block or head cracked that other problems probably exist. shift the transmission into each gear? does it go into each gear? does the engine turn over? if so, do you hear any grinding or strange sounds when you rotate the flywheel? other things to look for or at are the wheels. are they steel or round spokes or cast centers? look for rusted areas around value stems if so equipped. hoods, fenders, etc. are all available aftermarket so these are not big deals if they are all dented or smashed as most of them were during their long hard lives they have had. perhaps you have found a tractor that has been inside for the past 20 years or so and is a real gem. you might get away with having the magneto rebuilt along with the carb, put some fresh gas into the tank and after a few throws of the flywheels, you will revive that BR to life. i hope this is the case. but if not, to restore a BR or just to get it to run is not as bad as some other tractors are. good luck with your project and let us know how you make out.
DCM
11-14-2004 13:25:45
One problem with the BR"s are the steel wheels if you are looking for such. Especially the fronts.Have a 1945 model BR on rubber,great parade and show item.If its fairly complete, buy it. Dan in AB
Dan-CA
11-28-2004 01:34:11
 Re: FOUND A BR in reply to DCM, 11-14-2004 13:25:45
Engage the clutch and try to turn the pulley. If there is a lot of play here,then the crankshaft is worn at the clutch drive disk. I am not sure how expensive this will be. Generally, the BR is rare enough to rebuild the engine from scratch and still be of good value. All of this depends on your finances.
