1965 John Deere 1010 crawler loader ( transmission
SERGIO BORGES
11-14-2004 04:42:32
i JUST BOUGH A NICE OLD CRAWLER 1010 WAS RUNNING GREAT AND JUST HAPPENED I LOST 1 AND SECOND GEAR
SOUNDS LIKE METAL IS AGAINST METAL AND SOMETHING WILL EXPLODE
WAS VERY LITTLE TRANSMISSION FLUID ( MY FAULT)
DOES ANYONE HAVE ANY IDEA WHAT HAPPENED?
DOES MOVE ON 3 AND 4 BUT SLOW AND NO NOISE
ANY IDEA HOW MUCH TO FIX??
I REALLY LIKE MY DEERE
PLEASE E MAIL OR POST SOME HELP
[email protected]
jdemaris
11-14-2004 06:36:11
 Re: 1965 John Deere 1010 crawler loader ( transmis in reply to SERGIO BORGES, 11-14-2004 04:42:32
If you are sure it's a 1965, then the gear shifter is on top of the transmission, correct? The earlier 1010 crawlers have the gearshift in the dashboard. It will behoove you to remove the transmission top cover, look inside, and see what's going on. If you're lucky, it might just be a worn shift mechanism and a shift fork out of alignment. The 1010 transmission is a sliding gear transmission, not a collar shift. So, when you shift, entire gears move and go into, or out of, mesh. So, you either have gears NOT doing so because they are not fully engaging, or there are gear teeth broken off somewhere. It will all be self-evident once the top cover is removed.
sergio borges
11-15-2004 15:40:36
 Re: 1965 John Deere 1010 crawler loader ( transmis in reply to jdemaris, 11-14-2004 06:36:11
someone said tha to fix the transmission they have to remove the tracks and the front engine pull the transmission from behind. abd because is a gas engine , just trow in the garbage. its that true? no hope for a easy fix?
