70A loader on 855
REG
11-13-2004 19:38:07
I have a well maintained 855 with 300 hours, and a 70A loader. Cannot lift a full bucket of dry dirt more than a few feet off the ground. I could replace the lift rams with bucket rams that are slightly larger bore. Would that help me that much?? Anybody done that?? Any other ideas?? These rams are $360 each, so it would be a lot of money if it did me no good. Thanks for the help!! Rick
nitewowl
11-24-2004 20:26:21
 Re: 70A loader on 855 in reply to REG, 11-13-2004 19:38:07
I am looking at an 855 2wd with hydro and a loader. Can you guys comment on what sort of performance issues or applications that wouldn't work (or would) with this combination of equipment. If I proceed I would also get a 5ft light-med duty brush hog and a 5 ft box blade. I appreciate your comments regarding your experiences with this size/strength tractor and implements. Thanks.
REG
11-18-2004 17:44:48
Thanks for the feed back on my loader. The rams are installed as they should be according to the shop manual. And the line presure at the valve body is at 2000 psi. The book says 2050, so that is fine also. I tried another 855 same loader and even a smaller bucket. and that was no better than mine. Any ideas for swapping out the lift rams? Thanks.... Rick
Jerry Agan
06-05-2005 05:56:12
 Re: 70A loader on 855 in reply to REG, 11-18-2004 17:44:48
I recently rebuilt my 855 w 70a loader. During the painting process i removed the decal on mu left floor board that instructed what hydralic line to my loader goes to which hole. I still have the color bands on the line but could someone tell me in what order do they attach to the tractor? Thanks
leon
11-14-2004 19:24:23
Definately something wrong. Low pressure or too low of setting on the pressure relief valve? The 70A on my 855 will easily lift all the way up heaping full of rock. The lift cylinders aren't per chance, installed wrong way up are they?
hjp
11-13-2004 20:16:23
check your hydro presure first and replace your filter, rams are good if the seals are not leaking and with 300hrs its due for an oil change if it hasnt had one.
