B STEEL WHEELS
TIMAR
11-13-2004 17:17:03
Would a 35 4-bolt B have been shipped with rear skeleton wheels or the flat steel rims? Any how, I am looking for a correct set of 10 splines near Kansas.
JD4boltB
11-14-2004 13:42:04
 Re: B STEEL WHEELS in reply to TIMAR, 11-13-2004 17:17:03
timar, it would usually depend on where the tractor was being shipped as to what wheels it would be equipped with unless it was ordered a specific way by the dealer. some areas of the country would require the skeleton wheels whereas some other areas would require the flat steel. others may have been shipped on wheels for rubber tires. this was due to the types of soils in the different areas of the country. new england soils are different than soils in the plains states or texas. i have 2 4 bolt B"s and one was shipped on skeleton steel to iowa and the other was shipped to syracuse and on to CT on round spokes with rubber tires. if you check the B serial number registry guide put out by Two-Cylinder Magazine, you can check each tractor to see how it was equipped and where it went when it was new. it is also just a matter of preference how you equip your tractor depending on what you like in terms of the wheels you select. hope this helps.
TIMAR
11-14-2004 15:56:14
 Re: B STEEL WHEELS in reply to JD4boltB, 11-14-2004 13:42:04
It was shipped to Dallas, TX on Dec 31, 1934. Production book just has the AB 4 front steel, which I have aquired already
JD4boltB
11-15-2004 06:46:53
 Re: B STEEL WHEELS in reply to TIMAR, 11-14-2004 15:56:14
i have a friend in TX who regularly buys B's and he told me he, more often than most, usually finds them down there on flat steel. that is not to say you won't find them on skeleton steel. i am not sure which way you are leaning towards for putting rear steel on your B but if it were up to me, i would go with flat steel for originality. plus the lugs are cheaper to buy than the used skeleton lugs will be. i believe the basic wheel prices (skeleton vs flat steel) are probably about the same, at least they are here in my neck of the woods. i personally like steel on tractors and i am actually considering replacing my round spokes on one of my 4 bolt B's with flat steel and texas sand fronts. (the other 4 bolt is already on full steel w/skeleton rear). the cost to do this is probably what is holding me back right now as has been the case with some other projects i have going at right now.
Duane Larson
11-13-2004 19:55:31
TIMAR,
In principle, your B could have been shipped with either. The first skeleton wheels for the B were built by French & Hecht, and are thought to have been used to about s/n 12011 (ie, the first year). They have evenly spaced lugs, and are considered hard to find. After that, JD built skeleton wheels were used, and their lugs are not evenly spaced around the wheel.
However, A Deere & Webber (the Minneapolis branch house) bulletin dated 5/1/36 discourages use of skeleton wheels on the A and B in areas where the soil is "loose". The reason was that too much tractor horsepower was needed just to move the tractor, with an apparent reduction in available horsepower to do work (and increase in fuel usage to do work). They state "In making up the 1935 and 1936 Contract, the model "A" and "B" tractors were not listed with skeleton wheels". But other branch houses may not have had that concern.
Flat steel wheels are probably more easily available. The same ones were used for all unstyled B's, and were JD wheels with cast-in hubs using the B25R hub clamp. No casting number was used on the wheel. They had 10 splines, and 10 flat spokes and are 48" x 5 1/4" x 1/4" thick. Later on a bolt-in hub wheel was available (mid '40's).
TIMAR
11-14-2004 08:52:03
 Re: B STEEL WHEELS in reply to Duane Larson, 11-13-2004 19:55:31
Thanks Duane!!
