dieselrig
11-14-2004 12:00:31
Re: 620 Questions in reply to Ron H., 11-13-2004 16:41:26
We have two 620's one we pull with regularly that had the axle housing repaired years ago, not by us, but has held and been used alot, actually believe it had an accident because the tractor is a two owner with 2100 hours, pretty low hours, anyway, we did get a deal on it, but restored it and have alot of time in it, I see 3 point hitches for these at 1200 plus dollars, a top link will get 300 plus for an original, if you plan to use the tractor, I think 3000 is not that bad of a buy, lets say worst case scenario, the block goes, they are out there, I keep seeing one on this pages classified ads for 350.00. and the manifold, you can get it all for an aftermarket for 250.00 or so, so in the worst case, you have a 620 with good tin, tires, 3 point and new manifold and possibly a block, all for 3600 or 3700, I doubt you can find one with all that going for it for that money, as far as the comments on the welds on the block, there are alot of welds on stuff out there and alot of things are welded together, just remember your jack stands the next time you are under your tractor or truck, you dont really think about it do you?
