Insert Rod Bearings for Early B's
JDGnut
02-09-2004 09:43:39
Does anyone make insert bearings for the Early 2.25 journaled B Rods... I can have the rods cut for inserts.. but if I don't have any bearings it is useless... Anyone had this done.. I'm not going to install Babbited Rods in this tractor.. (Yes, I know they can be repoured..)
Thanks for any info..
JDGnut
JDGnut
02-09-2004 20:26:05
 Re: Insert Rod Bearings for Early B's in reply to JDGnut, 02-09-2004 09:43:39
Thanks guys.. Not worried about the crank being round.. it will be true.. as it will be changed from the bigger journal to the smaller journal... The machine shop that I use does a lot of racing stuff and they are very good.. but they don't have a clue when it comes to tractors stuff.. they just do as they are told... As far as finding a bearing.. the width of the bearing is the main concern.. I don't think the 2.25 dia will be hard to find... but I don't want them to have to weld the crank to grind the radius.. (Actually I think if the rest of the journal is cut to match the insert it will work... thanks for the Info.
JDGnut
Bus Driver
02-09-2004 15:55:38
To add to the other post about the babbit, with babbit, the crank must only be ground round, the two rod journals could even be different sizes. The babbit would be fitted to the crank. With inserts, the crank must be ground to match the inserts. Just something to consider.
Brokenwrench
02-09-2004 14:13:04
The machine shop that machines the rods should have access to a bearing supplier,they can't just machine a set of rods for inserts,without having some bearing specs. for the machine work. Also check your crank closely before you go the insert route. If the throws aren't true,or barrel shaped, a set of inserts won't last long. The babbited rods can be scraped,sanded,shimmed or massaged to match up to a not so good crank and give long service,where you can't do anything to the inserts.
02-09-2004 10:25:40
I believe the 50 rods will do what you want done....I've used them in B's for some time....but they are getting pricy....
JDGnut
02-09-2004 11:10:09
 Re: Re: Insert Rod Bearings for Early B's in reply to [email protected], 02-09-2004 10:25:40
Not a 100% sure.. but I believe the 50 rods has a 2.75 rod journal like the late B's???? I need 2.25 like the early B's.. Thanks
JDGnut
