Are 1010 diesel pistons same as 2010 gas
jd1010
11-13-2004 15:00:31
I was wondering if the 2010 gas pistons will work in the 1010 diesel, since there the same bore. the only thing would be the wrist pin that i can think of. Are they the same piston, if not will they work? Jason
buickanddeere
11-13-2004 17:48:53
 Re: Are 1010 diesel pistons same as 2010 gas in reply to jd1010, 11-13-2004 15:00:31
No where near. Used pistons tend to be worn anyways. Rings won't seal when fluttering around in worn grooves.
jdemaris
11-13-2004 18:23:05
 Re: Are 1010 diesel pistons same as 2010 gas in reply to buickanddeere, 11-13-2004 17:48:53
Diesel pistons are diffent than gas pistons (barring a few rare exceptions). Diesels have the combustion chambers built into the pistons. Gas engines have the combustion chambers built into the heads. So, they are not interchangible. Worn piston rings grooves is usually not a problem. They can be easily repaired with steel shims. It used to be a standard practice until labor costs got high and parts got cheap. But, now parts' prices are high enough where it's often well worth it to repair worn piston grooves. Parts cost about three dollars per piston. Machining cost? All depends on who's doing it. I had four pistons done recently for a total of $30 (i.e. $7.50 each) - so I had a total cost of $42 to fix four pistons. If the skirt is worn, that's a different story. Years ago they were repaired by knurling, but I don't know anyone that does it anymore. If I could buy pistons for $30 apiece, the old ones wouldn't be worth messing with - but with some of these tractors, the pistons are over $100 apiece.
