4010 24V Elect. Sys Data
txblu
11-13-2004 09:34:41
Been a lot of yakin lately about the 24 volt charging system on 4010 Diesels.
I was cleaning and shining (terminals) today and took some data. Thought you might be interested.
Batteries are < 6 mos old. 2 each Dynavolt Maint. Free DY31S900....900 CCA @0 degr F. Distributed by International Trucks and Engines, Inc. $56.00 each, no trade in required. Have screw terminals; no lead. (Physical size of size 27 Trolling motor battery like in fishin).
Cranked tractor from 50 degree morning temp. Let it get to operational temp. Measured across both batteries for VR output, then measured individual batteries to see how voltage is dividing.
RPM and VR output at battery terminal
800 = 26.5
1000 = 27.1 (Chg light went out @ 1200 rpm)
1500 = 29.7
PTO = 29.8
Measurements at 1500 rpm.
A batt 14v, B batt 15.7 Even though the tractor was performing normally with excellent starting characteristics, this is unacceptable as one battery is getting 1.7 volts more than the other which amounts to a lot of current. Gotta do something..... .didn't know it was this bad...no indications.....
Shut her down. Removed the batteries and swapped places with them....put the A batt on the B ckt and vice versa.
Checked battery residual voltage prior to new charging arrangement.
Batt charging at higher voltage read 13.31
Batt charging at lower voltage read 13.00
(These numbers are high but they just came off the charger....haven't had time to stabilize.)
Restarted tractor and ran to 1500 rpm'. Let things stabilize.
Ck VR output = 28.7
Battery voltage initial 13.75 where it was 15.7
and 14.21 where it was 14 v.
Let her run for a few minutes and reread:
13.7 went to 14.2 and 14.21 went to 14.96.
Difference is now .7 volts.
Lots better.
All things being equal, if your batteries are not charging evenly, and you have your loads split corectly, TRY SWAPPING POSITIONS ON THE BATTERIES.
See Ya!
Mark
Bob
11-14-2004 08:17:31
 Re: 4010 24V Elect. Sys Data in reply to txblu, 11-13-2004 09:34:41
As I have often previously posted, the condition of the batteries (and how well they're matched in exact part# and age) has EVERYTHING to do with how well these 24 Volt systems operate.
I have a 24 Volt 4020, and often had battery trouble with it until I learned to buy both batteries at once. I have been using Deere batteries, and got 5 or 6 years out of each of two sets, and have a couple of years already on my latest pair.
I had collected everything needed to change the tractor over to 12 Volts, and it's been on the shelf for 12 or 15 years, as the old 24 Volt system has been perking along with no repairs except batteries every 5 or 6 years.
A lot of these have been converted to 12 Volts, and that does work, with the posible exception of fuel gauge problems. However, in cold weather the 24 Volt system really shines in the way it can crank over the big diesel!
deeredug
11-14-2004 14:01:37
 Re: 4010 24V Elect. Sys Data in reply to Bob, 11-14-2004 08:17:31
I have a 24 volt 4020, do you have a gen or alternator? I have an alt 24v. that's not hooked
up,it's a one wire unit, I have'nt been able to wire it in.
thank's DugC
txblu
11-15-2004 07:24:49
 Re: 4010 24V Elect. Sys Data in reply to deeredug, 11-14-2004 14:01:37
Mines the orig 24 volt gen also. However when I bought the tractor a couple of years ago the charging system was kaput and I bought another one on www. with a new VR, very reasonably priced.
Mark
Bob
11-15-2004 06:46:24
My old 4020 has the original generator.
What make is your 1-wire 24 Volt alternator?
Most likely, you'd have to change Deere's split (grounded in the middle) 24 Volt system to being 24 Volt negative ground in order to use the 1-wire 24 Volt alternator.
Bob
11-14-2004 08:18:52
P.S....
tx, did you get a chance to hook the hay conditioner to the 4010, yet, and if so, how did the hydraulics work for you?
txblu
11-15-2004 07:28:53
 Re: 4010 24V Elect. Sys Data in reply to Bob, 11-14-2004 08:18:52
No sir, but I respected your expert advice and I'm not worried about it.
Since the tractor does have duals and both were being used (by the previous owner) I can't help but think that the second one was probably used for this function along with whatever else needed dual remotes.
Thank you.
Mark
Bob
11-15-2004 08:20:49
 Re: 4010 24V Elect. Sys Data in reply to txblu, 11-15-2004 07:28:53
tx,
It's always good, though, when my "expert advice" turns out to be correct, and that's why I was wondering how it worked out for you!
According to my wife, I'm never right, so I was just checking!
txblu
11-15-2004 10:01:21
 Re: 4010 24V Elect. Sys Data in reply to Bob, 11-15-2004 08:20:49
You found it huh! Great.
On the advice, I told my wife the other day that we were going to have to get along as she was going to be seeing me all day, every day.
Seems that she got the message (as I act more like a loving husband when she's not whining about something) and has been treating me really well..... course I started doing things around the house to start getting used to it..... ..... ..like washing the dishes. YUCK!
Mark
