Hard to Remove Injector
bodywash
11-12-2004 21:00:58
I am trying to replace an injector on my 84' JD 850. The old injector is proving impossible to pull out. I have tried threading a 6in bolt into the top of the injector and using it as a sort of slide hammer with a 5 lb weight. Still no luck. I am getting very frustrated. I would appreciate any and all suggestions. Also, I am not worried about saving the old injector - just need to get it out.
Thanks Scott
old
11-13-2004 06:33:45
 Re: Hard to Remove Injector in reply to bodywash, 11-12-2004 21:00:58
Take it loose and take the lines off and turn the engine over, it should shot out like a bullet. Be careful that no one or thing is in the way when you do so.
