Hi again G Guy, we cant have a G runnin like that for sure. Here's how I would approacht it, sounds like a fuel starvation problem possibly: The fuel pump cant help much if its more of an inside the carb restriction, and yes, it sounds like you may have internal carb problems. I forget what if any ignition things we already suggested???? You gotta have good plugs and a good hot blue spark firty ya know, post back any ignition info: PRELIMINARY, Make sure you have clean fresh water free gas and a good blue spark at the plugs and even try new plugs if you havent already. You might check the air cleaners lower bowl to see if its water free. That "choking helps her run" but she "still eventually dies" sounds more like the problem is the carbs bowl isnt gettign and keeping sufficient gas (or a float problem) than a nozzle restriction, so play plenty attention to the first gas flow test below. 1) Although you already tried it, turn the gas on at the tank/sediment bowl and open the carb bowls lower drain cock/plug and see if gas still flows about a pencil lead stream at least 30 seconds, then even a couple minutes to make sure. If so, enough gas is getting out the tank and sediment bowl and the carbs side inlet strainer and needle valve n seat. If not, post back for troubleshootign those problems. If the flow is slow or restricted out the tank,,,,, , or to and through the carbs side inlet strainer,,,,, ,,or through the needle valve n seat,,,,, she can run till she starves for fuel,,,,, ,,,, so make sure of the constant stream out the bowls bottom 30 secs to 2 minutes to be safe BEFORE going further. You might remove the side inlet strainers lil side plug and clean her out. Also, you could remove the strainers top circular nut and cap and clean the strainer out, and you may need a new top gasket. If you dont get that good continuous flow out the carbs bottom, either the tank or sed bowl or line or inlet strainer or needle n seat are clogged and she will run out of fuel????? ?? 2) Next, as posted below, have you tried to run the carbs top load needle a tad richer??? The rough in setting is about 3/4 to 1 turn out, try it richer n see what happens. 3) If theres sufficient flow of clean fresh water free gas out the carbs bottom (Para 1),,,,, ,, the plugs are yielding a good blue spark,,,,, ,, Opening the load needle dont help,,,,, ,,,,, (Para 2) but choking helps her run..... ..... ..... ..... 4) I suspect a clogged up carb or the float level is too low ASSUMING the ignition is good. 5) One possible cause is the carbs main center vertical brass nozzle is plugged up. To fix that, it may require tapping its small inner bore to get screw threads inside it so washers n nuts can be used as a puller to extract it down out of the bore. DONT bend or crush it up there in the top. Once out, thoroughlly clean and polish it ESPECIALLY all its lil side holes. 6) I dont have the exact specs, but I set the float levels so they shut the needle off when approximately level. 7) If it were an idle problem, I would talk about the idle passages behind those brass drill plugs, but lets fix the load problem first. 8) Another cause of leanign out are vacuum leaks. If you spray WD 40 or Carb Cleaner or an unlit propane torch around the carbs mount and the manifold base etc and she speeds up or smoothes out, you found a vacuum leak. 9) You might also take a look at the valve lash settings if the preliminary stuff above done help. Try these flow tests, try adjusting the needle, check the plugs and spark, and post back or e mail [email protected] with your findings. Good luck n God Bless ya John T Nordhoff
