4230 3-pt
C.K.
11-12-2004 16:36:44
My 3pt lift will not lift a load (round bail) high enough it seems to have power,but only lifts a small ways above the ground then stops.
Without any thing on, the arms travel all the way up, and there seems to be no leakage in the cyl. I found the control at the bottom of the console very stiff.I freed everthing up,and set to 0 but haven't tried it since. Could this have an effect? Are there other adjustments? Thanks for advice
david val
11-13-2004 08:37:03
 Re: 4230 3-pt in reply to C.K., 11-12-2004 16:36:44
older 4230's had a not very relieble 'reverse bend controller' which means that the load control shaft may be bended negatively, thus signling the arms to lower, while the normal control is signaling them to raise... this should not happen in 0 position. another thing may be low or not enough system pressure. if the load is higher then the hydraulic pressure at the rockshaft cylinder, then the pump will go out of stroke, you won't feel any 'load' on the teactor.
i think first thing to do is to make a thorough step by step rockshaft adjustment and pressure check.
david
