1940 JD B stiff, but not stuck
Lynn Kasdorf
11-12-2004 10:02:19
I am not quite ready to begin a real teardown and rebuild of this tractor yet, but I just am dying to at least determine what it is going to need.
When I got it, the engine was stuck. After diesel in the cylinders, and a long lever on the flywheel for a day, I got it to where I can move it. The tractor came with a homemade flywheel wrench gizmo that engages the two holes that I can snap a 3/4" ratchet onto. With a 6' pole I can force the flywheel around.
I drained the crankcase last night, and I got about 3 gallons of mostly water. I wonder if this thing has been in a flood? No sign of mud anywhere... Hard to believe that this much water could come from condensation.
I took off the top plate under the oil filler to look inside and there is no noticeable rust and everything has an oil coating. I have sprayed everything with penetrating oil.
It is still *very* stiff.
I don't know if the resistance is the cylinders, the rod bearings, the main bearings, or what.
I took the clutch apart and it was super rusty. It is totally off now (except for the outer pulley which I have not figured out how to remove).
So I guess that the bearings have been in water for so long that there must be rust inside.
I have been planning to fill the crankcase with diesel, rebuild the clutch, put it in gear and pull the tractor around to free it up. But if there is rust on the crank, this would probably introduce wear, so I guess I'll not do it.
Also, I pulled the transmission drain plugs and *nothing* came out. There appears to be some tarry crap in there.
I reckon a full rebuild of engine, and full cleaning of trans, rear, and lift is in my future. I was hoping to get the engine free enough to get it running, but I won't do a halfway fix if it risks damaging the bearing surfaces.
Mike M
11-12-2004 12:56:17
 Re: 1940 JD B stiff, but not stuck in reply to Lynn Kasdorf, 11-12-2004 10:02:19
Take off the valve cover and remove the push rods so they don't get bent if a valve is stuck,unless it is too late. Work the valves one at a time and check for sticking and if one is try to free it up. You should be able to feel side play in the rods if they are loose and also end play in the crank these should move freely just a little. Make sure the oil pump turns. I would oil it and put oil in it and try to run it before tearing it apart.
Loon Yi
11-13-2004 11:17:23
 Re: 1940 JD B stiff, but not stuck in reply to Mike M, 11-12-2004 12:56:17
Would you want to run something that was just freed up without tearing it down and seeing what is or was stuck? I ask because I recently freed up an old tractor which had one stuck cylinder and two stuck valves. I dont really want to tear it down completely right now, but would like to hear it run. I am afraid of further damage since while hand cranking there is a tight spot in one of the cylinders where it is hard to turn over. I have the head off and need to replace a seat and a few valves due to mice using the exhaust manifold as a 6 bedroom, 2 bath.
Mike M
11-13-2004 18:00:01
 Re: 1940 JD B stiff, but not stuck in reply to Loon Yi, 11-13-2004 11:17:23
I have got several old JD's back running again after being stuck without a tear down. If you can free it up with a bar on the flywheel it really wasn't stuck that bad,I have also had several that would not budge and had to tear clear down. You will need to get the diesel,or penetrant oil flushed out of the cylinders before it can start. I have done this by pulling them around the yard in high gear with the plugs out or better yet hook up a flat belt from another tractor this also works great for freeing up an engine that is tight and when you try starting it you can work with it better.
old
11-12-2004 10:35:54
Diesel is ok but tranny fluid or even used oild is better for looseing things up. Fill each cylinder up with tranny fluid and or oil and over fill the crank case if you aren't going to get to it soon
