520 radiator repair/removal
Gene in Bloomin
11-12-2004 07:32:13
I ran a tree limb through the radiator from the back side - the result, a hole in the radiator core and the fan blade is ruined. the 520 has power steering. Is the only way to get the radiator out to drain the power steering and then remove the hose and the pipe that cross directly over the radiator housing? If so, can I store the drained fluid in clean container and reuse it? I am very new to tractor repairs and/or restoration, but love my JD 520.
Mike M
11-12-2004 08:24:56
 Re: 520 radiator repair/removal in reply to Gene in Bloomington, IN, 11-12-2004 07:32:13
These 2cyl.tractors are hard to get the radiators out of. You would be farther ahead to drain the power steering and add new oil when you are done as most don't get changed that often because you can't get to the drain without taking the grille off. The hose and pipe will need to be unhooked and you may end up unbolting the steering worm gear housing to get more room,be careful as the gaskets are also shims and you will need to put the same amount back in. You said your fan blade is bad. This is also the time I would recommend you put new seals in that power steering pump since your right there. But that's your call if you want to take the chance they will not end up leaking soon.
Gene in bloomington
11-15-2004 11:43:34
 Re: 520 radiator repair/removal-more questions in reply to Mike M, 11-12-2004 08:24:56
I thought that if I removed the plug on the front of the worm gear housing, that the worm gear would just turn itself out through that opening, but it doesn't. So do I have to just remove the entire worm gear housing?? Like remove the 4 bolts on the side of the worm gear housing?? And the manual that I have talks of making a mark on the housing and the pedestal with a chisel so that when it goes back together, I can just line up the marks. What is that all about?
I did get the steering fluid drained and the hoses discounected. But the steering worm gear is still in the way of removing the radiator.
Thanks for any advice.
Gene
