730 PTO woes
Mayberry
11-12-2004 07:07:47
I have worked worked and worked on my 730 D PTO. It will not disengage. It spins all of the time. When I push back on the pedal to activate the brake It just loads the engine. The only place it will run is in the neutral position. I have replaced the brake plate, the driver plates, the adjusting cam and also the three steel balls that run against the adjusting cam. When I put it on the tractor it spins all of the time, and I can not enguage the clutches at all with the pedal even when they are adjusted loosley. It is almost like there is nothing giving "springing" when I try to enguage it. It is like metal against metal, and cant give. When installing the clutch packs and driver plates after putting on the last snap ring should I be able to turn them with my fingers to line up the driver plates? I had to use a small hammer to peck them into place. I am sure I left something out, but just ask and I will fill you in. Thanks so much
buckeye al
11-15-2004 15:49:06
 Re: 730 PTO woes in reply to Mayberry, 11-12-2004 07:07:47
I hesitate to reply because I've not ever been inside the 730 PTO clutch assembly but I don't see any replies for you. I have been into two 70's & a 60 but never a 730. ASSUMING (real dangerous) they're basically the same, I wonder if instead of leaving something out, you put too many in?
Seems to me I recall there being different numbers of driver plates & driven plates between early & later series tractors. Seven of one & eight of the other versus 8 of one & 9 of the other I think. I believe the change was in the 70 series. Hopefully someone with good parts books (I do not have available) can verify this. I know I bought one too many of each when I ordered parts for my 70. Parts man asked how many plates mine had. Didn't know, had not taken it apart yet so he sold me the big set. They're nice & took the extra pair back. My parts man (really great guy) led me to understand the later parts will fit in earlier units (as repair parts) so the number of plates is not necessarily tractor serial number specific.
I therefore wonder if a previous owner perhaps mixed some parts & you may be trying to install the later style number of plates onto an eary 70 shaft? Reason I say this is when in the released position (clutch disengaged & brake applied) the plates move very very freely. Slightest bump & they're out of alignment making shell installation troublesome. Gravity will move them all over the place unless the pack is engaged. If you had to tap them 'round with a hammer to get them to line up, that Chineese mechanic named "Sum Ting Wong" has definitely been at work inside your unit! If engaged, I think heavy hammering would be required & that would likely destroy plates before they moved.
You mention it does not function properly even when adjusted loosely. That has me confused. Unless the 730 is REALLY different form the 70's, the measurement to be taken is between the brake plate & brake hub with the clutch pack engaged. If you can't engage the clutch, how did you establish any setting that was even close? Not saying you're wrong here, I'm just not understanding something. Assuming the 730 function is the same as the 70 (like I said, this could be real dangerous) the early stages of clutch pack engagement (clutch motion) takes all the space out from between the drivers & driven plates. This motion is fairly easy because only the small disengagement springs are being squeezed. Only after you get all that slack out and in the last .090" (I think) of travel do you actually start to compress the big springs behind the brake plate placing serious pressure on the clutch pack, disengaging the brake and finally making the PTO run. This last bit of travel is not under normal circumstances all that difficult. If there isn't any spacing between the drivers & the driven plates to begin with, you're trying to compress the big springs right off the bat & that will be REALLY tough (basicaly impossible) to do!
Like I said, I'm not actually familiar with the 730 but I hope this helps you mull it over & maybe that bright light will lite up & you'll know what's wrong. Post back.
