4020 electrical
Smitty
11-11-2004 10:47:45
I have read the messages and still do not understand. I have recently bought a 4020 that is 24v. The left battery will not stay charged. I am tired of jumping off the tractor everytime I need it. I have charged the battery and it goes dead overnight. What should I look for or should I just change it over to 12v.
Thanks Smitty
WTW
11-12-2004 10:47:20
 Re: 4020 electrical in reply to Smitty, 11-11-2004 10:47:45
Smitty, The problem is that not everybody understands how these systems work (no offence) because they are unique and different. They can be repaired and do work well when repaired correctly. Rather than have a 24 volt training school here I will try to tell you how to isolate your problem by performing some simple test that you can follow to troubleshoot it. You said that your tractor will not start when left set overnight. This is because of one of two possibilities either the tractor electrical system is drawing down the battery or the battery is not any good. First determine if the battery is good by checking the tractor will start when it is shut off at the end of the day, disconnect both batteries and leave it set overnight or better yet longer before reconnecting them to see if tractor will start. If tractor will start, electrical system is drawing battery down, if it will not start the battery is junk. To isolate problem in the tractor electrical system, first make sure that batteries are connected to the tractor correctly. Right battery front post is positive and is connected to the side of the starter motor. The front post on the left battery is Negative connected to the top of the starter solenoid. The most common reason one battery goes down and not the other is a short to ground in either the charging or starting circuit, most often in the starter. Just because it will start and charge does not mean it is not drawing current from your battery of concern when setting. To determine if starter or something else is cause of draw disconnect all wiring from starter except the battery cables and leave set overnight again or longer to see if the battery of concern goes down, if it does the starter (the only thing connected to the batteries) is at fault. If not repeat this same test with wiring connected to starter and disconnected at the regulator and generator. Sooner or later something that you have disconnected will not cause it to drain on your battery when setting. One other thing you mentioned that could be a concern and can be tested the same way is to your key switch / circuit, switch it itself may not be at fault other than be the wrong part for the circuitry and the way it is connected to it. Disconnect all the wiring from it and repeat this test if needed. You can find your problem by a simple process of elimination. Good Luck, Dave W.
msb
11-11-2004 18:58:09
The regulater gets its information from the left battery only.IF the current draw isn't reasonably divided the right battery will either go dead(if the left battery fully charged) or will have the water boiled out of the right battery if the left battery has a greater current draw on it than the right one does.SO, in your case, you either have a dead cell in the left battery or the thrust washer on the armature shaft is worn out allowing the armature commutator to short out on the end cap of the starter.That would be my guess.Try switching the right battery with the left after recharging the dead battery and that should tell you where the problem is located.The ulitmate solution is to switch the tractor over to 12 volts and install an alternator.
Bob
11-11-2004 20:27:51
 Re: 4020 electrical in reply to msb, 11-11-2004 18:58:09
msb,
That's absolute bullpucky! The regulator senses the 24 Volts, (28+ Volts, actually) ACROSS THE TWO BATTERIES IN SERIES. It responds no more to the left battery than the right.
Assuming the two batteries are equal electrically (chemically?) the charging voltage will divide accross them equally.
AND hopefully, the operator will keep the loads equally balanced between the batteries!
msb
11-12-2004 20:36:01
 Re: 4020 electrical in reply to Bob, 11-11-2004 20:27:51
Well Bob,That is what I was told by Deere service engineers in service school a long,long time ago(1964).I used to plant with my 4020 years ago and had a monitor hooked up the right battery.It always ran the right battery down after a few days use.That is what they said was the resaon.If I hooked it to the left battery,it would boil the water out of the right side since the left side needed more charge current in that situation.
twopop
11-11-2004 16:10:34
someone recently had a discharging problem.it was in the starter solenoid.someone had installed a 12 volt solenoid,instead of a 24 volt.
G-dog
11-11-2004 14:54:24
Correct me if I am wrong, the only time the system is 24 volt is when you hit the ignition. The rest of the time, it is 12 volt, postive and negative grounded. Typically if the right battery goes down it is the starter, if the left goes down, it is the generator.
Smitty
11-11-2004 15:02:09
 Re: 4020 electrical in reply to G-dog, 11-11-2004 14:54:24
I have heard the right is the starter and the left is the generator before.
Maybe that will help trace it down. Is there something in the starter to check that is usually the suspect.
smitty
Gerald J.
11-11-2004 11:23:17
If the left battery won't stay charged, either that battery is bad or there's a leakage to ground discharging it. The starter and generator run off 24 volts and that uses both batteries. Accessories like lights are split between the two 12 volt systems formed when the center of the 24 volt battery is grounded as it is in the 4020 diesel. You could have a mouse chewed wire on that side or simply a battery that won't hold charge. The battery hold downs tend to be lost over the decades and I noticed on my 4020 gas that it wouldn't take much bounce for the battery posts to short against the floor and in the two battery system that would severely unbalance the battery charging.
If you have a leak from a light circuit being left on or a wire touching ground from mouse chewing, going to 12 volts isn't going to cure the problem, just its going to cost you the $600 for the JD kit to make the conversion.
For trouble shooting, ignore the starting an charging systems. Just think of it as having two independent 12 volt systems, one positive ground, one negative ground and search the system that kills the battery for the problems. Go to Walmart and in the RV department buy a 12 volt 50 watt lamp. Go to a home center and buy a fused (edison base fuse) switch to fit a handy box. Often used for a furnace. Get a few feet of flexible wire and some crocodile clips (at Radio Shack, an automotive store, or the home center). Hook the switch in series with the fuse socket and the pair in series with two pieces of flexible wire with clips on the outer ends. Screw the lamp into the fuse socket. Mount on a handy box. Disconnect a battery cable on the battery that goes down (but before it goes down). Connect the light and switch between the battery post and the cable. Turn on the switch. If the light glows or lights it shows you have leakage or a short. Separate the circuits on that 12 volt system to isolate the faulty one. When you find, it fix it.
I heard one recently where the starter solenoid had been replaced with one for a 12 volt starter that caused leakage to ground. Watch out for that. If you can't find any glow on the lamp, then maybe its the battery itself. Give it a few days disconnected and if its down it was the battery and that's a simple cure. A new battery.
Gerald J.
txblu
11-11-2004 13:00:26
 Re: 4020 electrical in reply to Gerald J., 11-11-2004 11:23:17
All of the above plus one more thought... or 2.
The idea behind all that engineering is the fact that the 24 volt gen doesn't know what it's feeding to each battery . It just puts out juice and hopes it is equally distributed.
What you might do is charge up the discharging battery till it is the same voltage as the good one. (Give it time to stabilize before you do this, say 8 hrs). Then crank the tractor and measure the voltage across both batteries (24 plus volts). Now look across each battery. If charging equal, half the 24 volt plus reading will be across each.
If your discharger is lower, it will explain your problem. Course your hot one should be running low on water as it is probably boiled out due to being overcharged.
Also, insure that your lights are on separate batteries as originally intended. One side of the tractor to one batt, other to the other. I think they call them the A and B circuits when you look at the back of your ign switch.
For shorts, remove the NON grounded terminal of a battery (with the key off and the other battery disconnected) and measure ohms to the chassis (the wiring harness side). There should be a very high resistance (Megohms) if anything. Then measure the other battery likewise.
Somewhere in all this if you didn't find your problem, get another battery.
Mark
Smitty
11-11-2004 11:44:19
 Re: 4020 electrical to Gerald J. in reply to Gerald J., 11-11-2004 11:23:17
Couldn't I use a volt/ohm meter to check for potential instead of the light?
Gerald J.
11-11-2004 19:54:47
 Re: VOM? in reply to Smitty, 11-11-2004 11:44:19
You could use a VOM except its too costly, too sensitive, and too confusing. The light is far simpler and sensitive enough and you can't hurt the light when you do get a solid short in the test process.
If you have the VOM on milliamps and short a wire with your screwdriver (or move that mouse chew to a solid ground) you blow the meter. All the light does is glow at full brilliance.
And then the super sensitivity of the meter can lead you astray showing minor currents that aren't the real problem. That's why I suggest the light (and use the light).
A good VOM starts at $15 and goes to at least $150 for something truly trustworthy. The light bulb, socket, switch, handy box and wires costs under $10 and I don't yet know how long the light will last. Mine has been going for more than 15 years.
Gerald J.
buickanddeere
11-11-2004 16:00:18
 Re: 4020 electrical to Gerald J. in reply to Smitty, 11-11-2004 11:44:19
A multi-meter can be used but amatures and even pros on occassion tend to leave them on ohms and try testing an energized circuit..... zap...poof. Has anything at all ever been done to the electrical system? Extra lights, fertilizer spreaders, crop monitors, forage harvestoer controls, instrument gauges replaced etc?
Smitty
11-12-2004 06:25:45
 Re: 4020 electrical in reply to buickanddeere, 11-11-2004 16:00:18
Nothing electrical has been added. I have gone over the wiring harness and taped all bad spots that I have found. The lights on the left side only glow while the lights on the right side shine full bright. I have removed the wires from the light switch but the wiring diagram in my manual does not match the switch. This tractor has a key and a push button to start. Does this sound like oem. The tractor previously spent most time in the barn and not used much. The batteries are about 2 1/2 yrs old.
Smitty
Gerald J.
11-12-2004 07:34:45
 Re: 4020 electrical in reply to Smitty, 11-12-2004 06:25:45
There were at least three versions of the 4020. The ignition switch with separate starter push button sounds like my '68 (gas). E.g. serial number between 91,000 and 201,999. The wiring diagram and harness is significantly different for the three versions. There is a workable diagram in the parts book which your JD dealer can print off for you.
If the lights only glow on one side of the tractor then there is a bad connection somewhere. They should have a different color of glow depending on how many are on if its a series resistance. But that could also be the case if the left side battery has a bad cell or is run down when you test.
The charging system on the 4020 is wimpy at best. Its designed to recharge the batteries taking all day. The way we use the 4020 these days, mostly short runs, that little generator (10 amps at 24 volts) even if its working properly can't catch up. On my gas 4020, I used to only get about a year out of a new battery and then it took hooking up the battery charger before I could start it. I got tired of that. It now has a 1 wire alternator, and a side terminal battery sitting on a shelf that replaced the left step (that includes two steps for getting on easier) and I don't yet know what the battery life might be. Three years so far and I've not had to charge the battery once, even when starting in the middle of the winter or after sitting for three or four months. The new side terminal battery came from Walmart, not an expensive purchase like those long skinny JD batteries.
24 volt alternators do exist, but are not common. Look for the Leece-Neville brand though they might be a bit big for fitting in place of the generator.
I also added an ammeter to help in the diagnosis and found after I'd worked on the generator that the regulator was slower than the ammeter so the ammeter needle bounced from peg to peg giving no useful information. Now with the alternator, it shows rapid charge after starting that tapers off in just a few minutes like it should.
The alternator is only original on 4020 with cabs, but it works so much better than the wimpy generator, I can tolerate it on my work 4020. Might not do for show, but my 4020 will rust before its shown. As far as I recall from the 4020 parts book for those before SN 202,000 all alternators were 12 volts. The biggest expense in a 12 volt conversion is the new 12 volt starter.
Gerald J.
Bob
11-12-2004 07:25:17
There is a chassis ground wire from the cable that connects the two batteries together to the tractor frame. This may have a slow-blow fuse in it. If this is missing, blown, or defective, you'll get weak lights on one side of the system.
buickanddeere
11-12-2004 10:32:33
 Re: 4020 electrical in reply to Bob, 11-12-2004 07:25:17
Sounds likely along with a short from brush carbon dust oof a failing winding in the generator,starter or regulator. The origional 10 amp 24V generator is pretty scrawny and only equivalent to a 20 amp 12V generator. An 18 amp generator winding set from a 840 from serial number 840500 + is much better. Almost every time a generator slow charging problem is encountered the following are found. Too low voltage regulator setting, worn pulley, worn/glazed belt. And the cheap skate farmer who shuts off the tractor rather than let it idle for two minutes while opening a gate. And never revs the engine near full rated rpms.
