JD850 Starting Problem
BFH
11-11-2004 03:25:23
When starting my cold JD850, the 3rd cylinder (closest to the radiator) does not kick in for maybe 10 seconds. The problem was worse until I changed the injector. Any ideas?
Mike M
11-11-2004 11:55:58
 Re: JD850 Starting Problem in reply to BFH, 11-11-2004 03:25:23
Did you bleed that line going to the injector ?It may have some air in it. Loosen the fitting on the line at the injector and crank the engine until fuel sprays out,or you could do it while it's running just don't let the fuel spray into your skin under pressure. Wouldn't hurt to adjust the valves as JD recommends every 500hrs. If these don't help it may get expensive.
