Painting Wheel Weights
Big Yarber
11-10-2004 19:31:57
I am in the process of restoring some john deere wheel weights and was wondering what type of paint i should use to paint them. can i use the spray cans of paint or do i need to buy a gallon of paint and hardner and spray with an air sprayer? thanks in advance
DiggerLarry
11-11-2004 10:18:52
 Re: Painting Wheel Weights in reply to Big Yarber, 11-10-2004 19:31:57
I painted mine with the JD Yellow from the JD dealer. A quart should do two wheel weights, front and back, if you prime with gray first. I do add hardener to mine. You can use raddle cans but it has no hardener and the final cost would be higher and can be hard to control runs. If you have a compressor and spray gun, mix and spray yourself.
