Hydraulic problems need help??
Tex
11-10-2004 16:55:19
I have a 3130 (same as 2840) with a 148 loader. When I got it, it had a lot of Hydr leaks, hoses, cooler, etc. I got all those fixed, replaced all the filters, and screens and changed the fluid. It works great for about an hour or until it gets hot. I use it to load 1500LB roll bales, which it handles very easy. One in ft one in back. Once it gets hot, the steering get jerky and the control box for the loader starts squealing. What do I check next, I hate to think its the pump, it seems so strong. Plus it's about $700.00 to rebuild. I can see it was recently rebuilt. Is there anything in the control box (hope I'm calling it correct, It has it's own control's) to redo?
Thanks
walter squires
11-11-2004 06:58:07
 Re: Hydraulic problems need help?? in reply to Tex, 11-10-2004 16:55:19
Open the hyd. filler cap on the rear of tractor ( up by the the center link) get a flashlight, start the tractor and look in the filler hole, if you see a mist of oil you need to rebuild the rockshaft control valve, this is very common on 2040 to 3155 tractors, not hard to repair but you do have to remove the rockshaft housing from the tractor. GOOD LUCK!
cannonball
11-11-2004 06:24:45
depends on how hot you are talking...if real hot then you have a leak probably on high pressure.. could be steering, rockshaft, pressure control valve, loader valve or even remote valve..one of the ways to find out if high pressure just bypass front pump if it has a destroking valve on it and listen to motor if you have high pressure leak on it, motor will be loaded. before fluid gets hot check every place you can where high pressure works for heat it will heat pretty quick .just normal operating temp..you have a transmission pump problem or internal leak have nice day may god bless
Tex
11-11-2004 08:20:43
 Re: Hydraulic problems need help?? in reply to cannonball, 11-11-2004 06:24:45
I did notice the main cylinders for the loader got too hot to touch. The dump ones were only warm. I want to try and fix it myself,
I just don't want to get in over my head, I don't understand much about about hydraulics.
Tex
11-11-2004 18:25:09
 Re: Hydraulic problems need help??more info in reply to Tex, 11-11-2004 08:20:43
Had to use it anyway to load a bunch of round bales. Blew a seal in one of the large cylinders of the loader. Was leaking pretty bad by the time I finished. Like I said, I don't know much about this stuff, but since it is clear, the pump was rebuilt, shortly before I got it.And as soon as I fix one leak another occurs, 5 times so far. Is it possible they did something wrong and it has too much pressure. or is that a dumd idea???
Jim Dunn
11-10-2004 19:31:10
I don't know anything about your system, but I was wondering if when you changed your hyd. oil, you replaced it with JD hydraulic oil. I used to have a 4230 that I tried to cheet a little on expences and bought a drum of oil with matching Military Specs. This was the only tractor that balked on that oil, but I finally had to flush the system and keep that oil out of it. There must have been something JD oil did for it. If you used a different oil, don't spend a lot of money on replacing parts until you at least try to get back to JD oil. No, I'm not a JD dealer, I just know what worked for me. Good Luck.
Jim
jdemaris
11-11-2004 06:26:50
 Re: Hydraulic problems need help?? in reply to Jim Dunn, 11-10-2004 19:31:10
We used alternative brand oils in many machines at the Deere dealership I worked at dating back to the 60s and never experienced any problems associated with not using the Deere brand. - as long as the oil was a suitable equivalent. Deere's "Hyguard" or "303" combination transmission/hydraulic oil was, and perhaps still is rebadged Shell Donax oil; not sure who makes it now but it I CAN tell you that Deere doesn't refine oil. Any good combination transmission/hydraulic oil that has the proper antiwear additives and is designed for wet clutches and brakes will work fine. AS far as the problems go in the 2840/3130, it could be one of many things. It depends on what options it has. Some of those tractors had a myriad of steel transmission pipes and o-rings that delivered oil to the independent PTO, reverser or Hi-Lo, etc. and sometimes sprung leaks. Such leaks resulted in the main hydraulic pump starving for charge oil from the transmission pump. With any Deere closed-center hydraulic system, when there's a problem - number 1 issue is to ascertain if the main hydraulic pump is getting enough oil to run since it is incapable of drawing oil on it's own. Once you know whether the problem is a low-pressure charge oil problem, or a high-pressure main system pressure problem, the diagnosis procedure is quite different. Rule-of-thumb low-tech diagnosis (not always acurate) is - when the pump squeals it is starving for oil and the problem is in the low pressure transmission charge pump circuit. If the pump hammers/knocks then the problem is likely to be in the main pump circuit. One other thing you might look for. Some of the hydraulic control valves that Deere used, especially on loader tractors were "convertible." That is to say, they could be used in either closed center or open center hydraulic systems by changing a large "conversion" plug. Sometimes the internal seals blow off that plug, the valve gets hot and squeals, and the hydrualics go haywire once hot.
TEX
11-10-2004 20:08:25
No, I buy everything from the John Deere Dealer, they are a 48 mile one way trip for me, but that's all I use. It mostly likey had this problem before, I just never used it for very long, because it leaked from all over the place. Thanks!
