JD 2950 Tach doen't immediately work after startin
Jbsimmo
11-09-2004 20:06:27
When I start my 2950 mfwd the tach doesn't work untill it goose the engine. After that it works fine until the next time I start it. Any ideas? Since I've owned it it has acted this way and it is really irritating.
Bob
11-09-2004 20:15:18
 Re: JD 2950 Tach doen't immediately work after sta in reply to Jbsimmo, 11-09-2004 20:06:27
At the back of the instruments is a printed circuit board, with contact pins, etc. soldered to it. From time, heat, and vibration, the solder joints there crack loose, and you have intermittants, and thermal intermittants.
Carefull disassembly, and resoldering of the joints with the appropriate radio-TV solder will solve the problem.
(Been there, done that, several times.)
