Ken Your year and sn would help here, But this is my version of what is happening. I crossed out the AM3433T number in my book and it is for a HiCrop/Tricycle/Special The number for the W is AM3432T. However that is for the tom's that have the late model rock shaft housing - the ones with the bushings in them. If you got the old housing without the bushings the number should be M2107T - assuming that that is the seal you are wanting since if you have a dual tom there are more seals. That number may cross over to another one when the parts man looks it up. We could start another long winded discussion on when the housings changed, but I am convinced that they started going on the 420 in late 58. Anyhow to settle the deal, if you have had the rock shaft/shafts out it will be easy to determine if it has bushings or not. Also somewhere on the housing will be a part number (I think under the left side, If it is T12735T you have the new type rockshaft housing with bushings. If it is something else you will probably need the seals as listed in the manual for the housing up to sn 158437. Also, you porbably already are up on this but if you have the dual tom, there is a seal also inside the short shaft that seals the oil from running between the hollow shaft and the main shaft. Hope this gets your parts man headed in the right direction, but confirm what type of housing you have also to get it the first time. Good Luck
