Hydraulic Cylinder Question
bryani289swmi
11-09-2004 15:11:29
I have a cylinder for raising and lowering plows, planters, etc. for my 1951 JD B and it blew the lower gasket out while disking. Does anyone have the actual cylinder part number so I can be sure I can have this to hopefully get the gasket from my local JD dealer. If they wouldn't have this part arer therer any other sources? Also while I have it apart are the cylinder seals available and would it be wise to just go ahead a replace these as well? Thanks.
Bryan
2510Bill
11-10-2004 22:06:16
 Re: Hydraulic Cylinder Question in reply to bryani289swmi, 11-09-2004 15:11:29
You should be able to get the parts from JD. Might be best to take the cylinder into the dealer with you. Generally the casting no. on the cylinder housing will tell them which one it is. Not a bad Idea to take off one end or the other first so they can measure the piston bore as there were 2.5, 3.0 and 3.5 inch ones made. Yours may or may not be the right one for your tractor. Any of them will work with your B though as it is a low pressure HYD system. Only caution is that the B system was designed to work on 30wt oil I believe and not HYD oil. So make sure to not contaminate your tractor system with the wrong oil. Also be sure the bolts are excactly the right length (get your dealer to print the parts schematic for you) as you will break the guides if they are wrong. They use strange lengths like l 1/8 in. I use pipe joint compound on the bolt threads to avoid leaks. Ive rebuilt a few of these old cylinders for my tractors and have usually spent less than 50$ unless I had to buy the end guides which are very expensive. Good luck.
Hayfarmer
11-09-2004 19:40:03
I had an A cylinder apart last year. Tried to get parts from JD and couldn"t. What blew out? Just gasket between end and cylinder? There is O ring there as I recall. I had a leak at the shaft end and found it was a chevron type packing. My JD dealer happened to have one ordered for someone else but not picked up but you can get those from a hydraulics shop. If cylinder holds up ok I wouldn"t worry about cups inside. Mine had a gasket behind cups that was bad, I cut a spacer from leather on an old shoe and put behind them. If it is just O ring you should be able to match it up.
F-I-T
11-09-2004 16:52:02
Bryan:
It really depends on the cylinder you have. If, repeat, IF, you have an original JD cylinder as sold with the "B", or the slightly larger one sold for the "A", or the even larger one sold with the "G", or a more modern one sold with the 50/60/70 etc., you can probably get parts for it at your local John Deere dealer. The appropriate exploded parts diagram is located in the rear part of the tractor parts manual for those original type cylinders.
Frank
