Help! JD 60 Clutch
Flint
11-09-2004 14:40:52
Can anyone help me with the adjustment of my hand clutch. I put new facings in. I can't seem to get it to snap in like the manual says. The lever dosen't want to break over center. The tractor will move a little in 1st, 2nd and reverse but not with much power. I kind of have to push on the lever to get this out of it. Any help would be appreciated.
Fred from MO
11-10-2004 02:31:48
 Re: Help! JD 60 Clutch in reply to Flint, 11-09-2004 14:40:52
I had the similar problem with my 60. If you cannot get it to feel correct after evenly adjusting the 3 adjuster bolts. I would pull the entie pully off and check the backside for stuck or worn toggles etc. I had a froze clutch adjustor bolt preventing a dog from the cam over action it performs. Once freeing this up it works pretty well.
Good luck
Flint
11-11-2004 17:44:21
 Re: Help! JD 60 Clutch in reply to Fred from MO, 11-10-2004 02:31:48
Thanks for the help, it appears I'll be pulling the pulley off this weekend. Can't seem to get it adjusted. I can't move my wheel as it is rusted so hopefully I'll have enough room to check things out.
DP
11-09-2004 20:43:14
Try readjusting it making sure are nuts are pulled up evenly. If that doesn't correct the problem, it could be that the dogs and toggles are getting worn to a point that they need replacing, or the more common problem might be that the pin the sleeve moves on is worn out, or the ear that moves on the pin is worn through. No way to know for sure without pulling the clutch off. Don
Maark
11-09-2004 15:23:46
Loosen the three castellated nuts, engage the clutch lever then tighten the nuts evenly until the pressure plate makes contact. This should get you to move. You may need to adjust further afterwards to get a positive snap.
