G alternator and wiring
JD G GUY
11-08-2004 13:56:28
i am in the process of putting my g back together after having to recore the radiator and wire it. i have an older general motors car alternator, off an old chevy truck mounted but i need to know how to wire everything with the new alternator. will I have to use the regualar small pulley that came with the alternator or will I have to switch over to a large pulley like on the original generator? any help will be greatly appreciated as wiring and electrical is not a strong suit for me. Thanks.
John T
11-09-2004 14:06:04
 Re: G alternator and wiring in reply to JD G GUY, 11-08-2004 13:56:28
G Guy, if you e mail me I can return e mail a wiring diagram. As far as the pulley size, the smaller the Alternator pulley the faster it will turn so you may as well use it. That GM is a Negative ground alternator, so to use it you will need to convert to Negative ground you know which involves swapping ammeter leads so it dont read bass ackwards.
John T [email protected]
