855 John deer tractor hydro problem
Donald Williams
11-08-2004 13:32:32
I have an 855 that will not move in forward or in reverse pedal. the 3 point rear lift works ok and the power steering works. I replaced the front seal on the input shaft and changed the transmission oil filter. Can any body give me a clue as to what to do to correct the problem. Thanks Don Williams.
leon
11-09-2004 19:47:33
 Re: 855 John deer tractor hydro problem in reply to Donald Williams, 11-08-2004 13:32:32
Also check the safety interlocks. It isn't supposed to move if no one is in the seat and sometimes this linkage can go wrong. Also, I believe the manual says to fill the transmission filter with oil before putting it on. Did you do that? If not, you may want to loosen the filter to see if there's oil in it. If not, I'd suggest pulling it off and filling it before putting it back on. Sure, this will be messy, but apparently it helps the pump to prime.
F-I-T
11-08-2004 15:30:38
Donald:
I'm not near my books, but just wanted to say you need make sure you check the simple stuff.
Make sure the Hi/Lo range is not sitting in between the notches. That will make it act like that.
If you still have problems with it by the weekend, post back and I"ll post the trouble shooting steps.
Hopefully you'll have it figured out by then.
Frank
walker
01-21-2005 20:31:22
 Re: 855 John deer tractor hydro problem in reply to F-I-T, 11-08-2004 15:30:38
Hi Frank Got A problem with my 855 jd compact tractor I"m experiencing A total disengagement of the transmission after depressing the pedal forward or reverse it will move fine for a short distance then pop out of gear. with moving the pedals for and aft it will rengage and go for a short distance and pop out again. I removed all filters with normal wear and the rear housing cover and found no damage to the ring and pinion or other gears or components put new gear oil in and the same results i want to add it does"t matter if it in high or low range settings on shifter.
thanx Alex in IN. (765)808-6321 thanx for your time
Donald Williams
11-10-2004 12:50:57
Frank: Was unable to get back until now. I tried what you said did not work. Can you e- mail me the trouble shooting steps. Thanks Don W.
F-I-T
11-10-2004 13:19:51
 Re: 855 John deer tractor hydro problem in reply to Donald Williams, 11-10-2004 12:50:57
Donald:
I get home Friday evening. I'll try scanning them and e-mailing them to you.
Make sure I have your e-mail. Mine [email protected]
Frank
BILL DILLING
11-29-2005 17:10:12
 Re: 855 John deer tractor hydro problem in reply to F-I-T, 11-10-2004 13:19:51
YOU NEED TO DROP THE HYD DOWN AND PUT A NEW BOLT TO HOLD GEAR ON DRIVER ABOUT 8 HR IN SHOP YOU CAN DO AT HOME .BOLT BACK OUT DRIVER.
NEED NEW BOLT R57725 AND WASHER 24H1909.AND TWO ORING U15973 AND U42702.
