JD 1020 throttle
Larry in Lone J
02-08-2004 19:59:43
Anyone have any idea how to adjust the tension on a JD gas 1020 throttle? It holds fine at higher rpm's but will slide back to idle at mid to lower rpm's. Thanks in advance.
david val
02-09-2004 01:56:04
 Re: JD 1020 throttle in reply to Larry in Lone Jack, 02-08-2004 19:59:43
older tractors have adjusting nut on the throttle shaft. anyway, there are friction members that should move freely along the shaft but are keyd to rotate with the shaft. they usually get stuck with corrosion on the shaft and when friction facings wear, spring force return throttle to low. best thing to do is to disassemble clean and reassemble the whole mechanizm (you need to remove right battery cover for access).
david
Larry in Lone Jack
02-09-2004 04:11:40
 Re: Re: JD 1020 throttle in reply to david val, 02-09-2004 01:56:04
Thank you! I'll give that a try.
