Bush Hog
Duben
02-08-2004 19:49:31
Any secret to getting the blades out of a Bush Hog? Got the nuts off from the top but can't get the bolts out even with a ball joint splitter. I know it's not a John Deere, but I use a John Deere to pull it. Thanks for any suggestions.
Pete/ME
02-09-2004 02:42:49
 Re: Bush Hog in reply to Duben, 02-08-2004 19:49:31
P-B Blaster for a few days and a little heat (a Bernz torch should be enough).
Ron
02-08-2004 20:54:36
I guess you may need to soak them for a while... They must not have been off for A While..!!
I think I would put a good hard support under the pivot..just behind the Bolt, run the nut back on, and try driving the bolt down with a good drift, and a heavy ( 10 Lb or so ) Hammer.. No reason why they won't come out, except rust and dirt.. Grease them well, when installing, and they will come out easy..!!
