You need to oil up the linkage so it moves freely, and verify that you can feel the detent in the transmission drop into place as the shift lever is moved into the fourth gear position. If the linkage is adjusted incorrectly, the detent will either drop into the shift lever in the tranny, and then pass that point, if the linkage is off one way, or if the linkage is off the other way, the lever in the transmission will not move far enough for the detent to drop in place before the shift lever reaches the end of it's travel into the 4TH gear position. The actual detents in the tranny could be worn, or the "dimples" they drop into in the shift lever could be worn, or a detent spring could be weak or broken. On the "worse" side of things, a shift fork may be work or broken, or a shift collar, and it's associated splines may be worn out, not to mention a damaged or worn "high" synchro that is not letting the collar shift all the way into position.
