60 head gasket leak
gathje
11-07-2004 19:17:59
Did 1st class over haul on 60 jd because head was leaking and engine had normal wear.Put in new 45 over pistons, rebuilt head,hardened seats,should be like new ,runs perfect.Every time the engine gets pulled a little hard the head gasket leaks.I think only to the out side.Does`nt boil in radiator.Heat stays below 170.Lots of power.Just leaks out of head gasket.Retightened head put in 1can stop leak.Still leaks Thanks for any advice again.
Mike M
11-08-2004 05:09:02
 Re: 60 head gasket leak in reply to gathje, 11-07-2004 19:17:59
I would put in a big can of Bar's Leak and then go plow for a day then see what happens.
Mike Aylward
11-07-2004 19:38:25
Gathje, this is a common problem of the late A and 60 tractors. If a hot head retorque won't fix the problem the answer is to get another head gasket and follow this procedure: put #3 Permatex on the outside vertical rails of the head gasket on both sides, then torque the head in 10 ft./lb. increments until you hit 150 and then re-do it after the tractor is warmed up. Since I have been doing this I have never had one of these tractors to leak on me. Deere addressed this very problem several years ago and suggested the Permatex. A small increment torque method is my own addition to it. It works. Mike
gathje
11-07-2004 20:20:33
 Re: 60 head gasket leak in reply to Mike Aylward, 11-07-2004 19:38:25
Thanks a lot Mike .Thats what Ill do.After spending that much another head gasket is no big deal.Glad there is a fix.I think it leaks alog the top too so may go all areound the outside of gasket with the permatex3 . Thanks Martin Gathje
buickanddeere
11-07-2004 20:16:29
A set of new hardened tall nuts, hardened washers and some cam assebly lube on those threads can't hurt either. Some of those studs maybe getting stretched after 48+ years of service? Was the head and cylinder block planned flat? How coarse or fine was the grinding wheel used on the surfacing planner? 170F is still too cold. So many people think if boiling over is bad then colder is better. As Mike said, proper torquing will make or break the job even if everything else is perfect. I had a real eye opener in the tech school labratory where each bolt had a strain gauge and indicated clamping force as we torqued down a flange. Small steps and careful sequence is vital. A calibrated torque wrench is required too. Drop one a few times or use as a breaker bar and they are trouble looking for a place to happen. Engines don't even start to run clean until 180+F. It's sudden thermal shock from rapid temp changes that pops gaskets. Loading a cold engine hard is a classic..... ....woof & spray.
gathje
11-07-2004 20:36:34
 Re: 60 head gasket leak in reply to buickanddeere, 11-07-2004 20:16:29
Used new nuts and those lead washers from John Deere.Don`nt know how coarse the grinding equipment for head was but the shop was atrusted shop where they do a lot of engine work.Maybe Ishould put my old thermostat back in .Think the origonal was hotter.Don`t know if aguy can even get new head bolts any more for that tractor? thanks.
MAD DUC
11-09-2004 18:04:14
 Re: 60 head gasket leak in reply to gathje, 11-07-2004 20:36:34
Mother Deere still has the head studs and block to main case studs. Replaced all mine on my A and she has no leaks.
buickanddeere
11-07-2004 22:28:09
Any fastener/bolt/hardware shop in the yellow pages has studs in sizes and strengths for anything. Price is decent too. If the wheel was too coarse there will lots of "tooth" to bite into and hold the gasket but the surface will have sealing problems. A mirror smooth surface will seal well but has more tendency shift the gasket. Just make certain there is a wee vent hole in the thermostat so any vapours can go to the rad instead of insulating the thermostat in an air pocket.A very small trickle of water through is required as well during warm-up. The later tractors and LP units had a bypass line that took care of that problem during warm-up. If there is lots of compression, plenty of ignition advance and the engine is lugged hard on 87 octane "tractor gas" detonation can occur. The pressure spikes can be 2,3 even 4 times more than normal cylinder pressure. There goes the gasket.
gathje
11-08-2004 04:32:32
 Re: 60 head gasket leak in reply to buickanddeere, 11-07-2004 22:28:09
BUCKANDDEERE AND MIKE Thanks for all the help . Printed all you messages .Will follow the advice you gave.Very valuable. Thanks Martin Gathje
