730D electric start
CFWelles
11-07-2004 16:35:31
I recently bought a 730D and have been going through the tractor checking adjustments and changing lubricants where needed. The tractor needs a good cooling system flush and new antifreeze and water. Can any of you fellows tell me if you can disassemble the housing bolts containing the thermostat without removing the approximately 2" inlet pipe from the engine to get the thermostat out. Understand that the o ring seals for these pipes can be a little cantankerous to seal at times. Looks like getting the thermostat out for a radiator flush is more than a simple job. Just wanted to know the best way to get this done. I would appreciate some advice from any of your fellows who have done this. Thanks.
Dean
11-08-2004 07:24:06
 Re: 730D electric start in reply to CFWelles, 11-07-2004 16:35:31
I cannot answer your question regarding disassembly but will provide my 2 cents worth regarding radiator flushes. Though I once believed in routine radiator flushing using commercial products, I no longer do. My experience has taught me that far too often water pump seals fail shortly after using commercial radiator flush products. I stopped using such products about 15 years ago and do not remember changing a single water pump since. When flushing, I use plain water. Of course when refilling you should use only distilled water and anti freeze.
Dean
CFWelles
11-10-2004 03:31:33
 Re: 730D electric start in reply to Dean, 11-08-2004 07:24:06
Appreciate your comments on commercial cleaners. I was tempted to use one because there is guite a bit of sludge showing in the radiator. Think I will try using water alone first. Thanks again.
