John Deere G questions
john
02-08-2004 18:53:53
How do you adjust or tighten the linkage on the clutch and clutch handle. The clutch handle comes way back when disengaged. Thanks
Gman
02-09-2004 18:16:31
 Re: John Deere G questions in reply to john, 02-08-2004 18:53:53
John you might want to check the rod that actuiate the clutch,I was plowing with a rope tied to clutch lever,and the plows tripped (by the way if you try this be sure to keep your knee out of the clutch levers way it realy smarts when that lever smacks your knee cap)the actuating rod was broke in the splines but clutch still worked but clutch rod would give just enough where it would desengage clutch but would lay clear back if the clutch lever is real spongey you might want to check and see if its broken,I had to take the assembly clear apart before I could see if it was broken because it want break clean just an ideal later Gman
Pappy
02-08-2004 23:48:50
If you want to adjust the lever only, you can do so by adjusting the turn buckle on the control rod that goes forward from the bottom of the hand lever. If you lengthen the rod, the lever will be moved forward, etc.
