Oil light coming on
Mark
11-07-2004 16:05:17
Fellers,
I have a 1981 JD 1050 with a 3 cylinder Yanmar engine..30 something horse with a turbo. I use Rotella 30W oil and as of late, the oil light has been coming on when I throttle back to 1500 rpms after working the tractor hard...like plowing. When the machine is cold as at start up, I never have this trouble and if the machine hasn"t been worked hard..like mowing, it doesn"t do this. Therefore, it is apparent that the oil is thinning as it gets hot BUT is it also indicative of worn bearings not holding pressure? The tractor only has 1480 hours on it and I have owned it for 20 years. Yeah it lives an easy life! I considered changing the oil sending unit out to see if it was going bad. This machine gets the oil changed twice a year, generally with only 40-60 hours between changes. It has never been gutted/overworked. I pull a single 16" plow and mow with a 5" finish mower. It has been a fine machine but I am beginning to grow concerned about a future engine problem.
Bob
11-07-2004 16:33:34
 Re: Oil light coming on in reply to Mark, 11-07-2004 16:05:17
Before getting too drastic, install a temporty mechanical oil pressure gauge in place of the pressure switch, and verify your actual oil pressure.
Electric sending units (pressure switches) can and do fail.
Mark
11-07-2004 19:55:21
 Re: Oil light coming on in reply to Bob, 11-07-2004 16:33:34
Bob,
That is the same advice my son-in-law gave me this evening and is exactly what I plan on doing. Thanks very kindly for taking time to comment.
Bob
11-07-2004 20:31:54
 Re: Oil light coming on in reply to Mark, 11-07-2004 19:55:21
I wish I could tell you what the factory spec is for minimum oil pressure, but I have no detailed information on that little fella.
txblu
11-08-2004 07:19:02
 Re: Oil light coming on in reply to Bob, 11-07-2004 20:31:54
Being that I'm an "adequate oil pressure freak", I was awed and amazed to find that most IDIOT (that's what they are) lights will extinguish at 11 to 18 psig. Can you believe that?
Put in the gauge..... and while it's there whydoncha just leave it.
Since you know the hours are real, and know the usage, and with your maintenance schedule, and with Rotella T 30w twice a year; no reason to suspect your PAMPERED BABY has any reason to be a bad boy. Sounds like it ought to be huggin you. Grin
Mark
Bob
11-08-2004 08:53:29
 I agree, TX, and then... in reply to txblu, 11-08-2004 07:19:02
there's the guy in the post above worrying because his tractor has TOO MUCH oil pressure! We should all be so lucky!
txblu...yeah!!!
11-08-2004 11:56:25
 Re: I agree, TX, and then... in reply to Bob, 11-08-2004 08:53:29
