4010 Knock
Hoosier JD
11-07-2004 07:57:51
Hey...Hope you can help!
I have a 4010 gas with 7400 hours that I have had for 3 years. I have done a lot of work to it including water pump, radiator, electronic ignition, positive ground to negative ground, alternator, new tires and wheels all the way around, and so on. I thought I was ready to plow snow for my neighbors and myself here in central Indiana, but after changing oil and filter, while I was taking my kids a ride, I thought I heard a new sound..... .knocking coming from the front of the engine....possibly a rod bearing? If not a rod, could it be something else? Is it possible to pull the pan and change the rod bearings? Or am I going to have to pull the motor and rebuild? Big dollars if I take it to my local John Deere dealer? Anybody know of anybody here in central Indiana (Pendleton) that would do that kind of work? Sorry so long.... thanks for any and all help you guys can give! Been reading for a long time..... ....I really enjoy this site! Mike
Hoosier JD
11-21-2004 18:37:04
 Re: 4010 Knock in reply to Hoosier JD, 11-07-2004 07:57:51
It wasn"t the coupler, it is the front cylinder rod bearing. Going to take apart, measure and get new bearings and rod bolts. Thanks to all.
Hoosier JD
11-08-2004 15:46:02
Thanks for all the help! I'm draining the oil tonight and plan on pulling the pan off tomorrow night to see what it looks like inside. My coupler is a simple aluminum piece that bolts to the crank and the pump. I had it off when I redid the radiator and put a new water pump on last fall. Might be it, but the knock seems to be in that front cylinder. MSB, I appreciate the offer and will let you know after I find out about the bearings. email [email protected]
matthies
11-10-2004 19:40:16
 Re: 4010 Knock in reply to Hoosier JD, 11-08-2004 15:46:02
If it's a new sound, I would have ran the engine without the pump coupler on and then with the fan belt off(alt.and wp) for a short time, just to eliminate those items. Just one thing, Deere's rod bolts are a one time use, Once they're tighten and then loosened you replace them. Hate for you to pull the pan, find nothing, and then wonder what to do next. I have seen the coupler and bushings worn bad enough to knock. good luck chris
S. Conner
11-08-2004 10:31:22
If you have the original hydraulic pump coupling on there which consists of two spring steel disks and some spacers than this is probably where the noise is coming from. Does it just knock when you turn the steering wheel or push the brake pedals or operate any other hydraulic function? This is what mine was doing so I changed the coupling over to the new style like on the 20 series.
ET
11-08-2004 04:36:38
Check for worn splines inside the hyd. pump drive coupler. Sometmes just tightening the clamp bolts helps.
Maark
11-07-2004 11:28:23
The bushings in the hydraulic pump coupler will make that kind of noise when they get worn. You will have to remove the two aluminum halves to replace them. Very easy to do and check out.
Bob
11-07-2004 09:10:01
First, thoroughly check out the front hydraulic pump drive. Looseness there will make a heck of a knock.
Hoosier JD
11-07-2004 09:14:59
 Re: 4010 Knock in reply to Bob, 11-07-2004 09:10:01
I"ll check that out right now. Thanks
Hoosier JD
11-07-2004 09:44:03
 Re: 4010 Knock in reply to Hoosier JD, 11-07-2004 09:14:59
The pump is tight and wired. I'm worried that it is bearings or wrist pin.
msb
11-07-2004 18:26:59
 Re: 4010 Knock in reply to Hoosier JD, 11-07-2004 09:44:03
Replace the connector bushings on the hydraulic pump drive coupling before you proceed with any other tear down.They can appear to be tight but the nylon bushings can still be bad.You can cut the old ones off with a pocket knife and tap new ones on with a hammer.Retighten both sides of the coupler equally.Where in central Indiana? I am located in Fishers.
ET
11-08-2004 09:05:52
 Re: 4010 Knock in reply to msb, 11-07-2004 18:26:59
The style coupler you are refering to didn't come into use until 4020's and 3020's came along. Though some 10 series may have been upgraded.
msb
11-07-2004 18:35:44
Silly me.I didn't read all your post.Pendleton?Yes, you can replace the rod bearings without a rebuild, but I seriously doubt they are bad.IF the new bushings don't cure it I could run over and take a listen.My farm isn't very far fron where you are located.While you have that coupling apart it is a very good time to replace the fan belt if it needs it.
