160 lawn tractor won't charge the battery
winston
11-07-2004 07:10:47
I have an older JD 160lawn tractor with a 12hp Kawasaki that stopped charging the battery. I replaced the rectifier/ regulator, new battery but it still is not working. It runs when jumped to start but does not restart?
Hoosier JD
11-07-2004 10:23:54
 Re: 160 lawn tractor won't charge the battery in reply to winston, 11-07-2004 07:10:47
The idiot light bulb also has to be good, if it has one. The circuit will be broken and there will be no charge if the light is bad. I found this out the hard way.
Henry J
11-07-2004 07:55:55
Winston
Here may be another theory. I would think it would only apply if you are using something besides the battery terminals to jump it. If you are jumping the hot side directly to the starter lug you may be bypassing the problem and it will be in the starting electrical system.
I would also verify that it is not charging by putting a volte meter on the bat terminals. If it is charging it should be showing something like 13.2 volts when running.
Those two check should tell you which side of the electrical system to work on
good luck
John T
11-07-2004 07:35:38
Winston, Im unfamiliar with that particular tractor, but in general terms, the charging system consists of the two wire AC alternator (under flywheel),,,,, ,,the rectifier block (2 wires AC in, one wire DC out),,,,, ,,then current flows to and through the ammeter (if it has one) to the battery. So, if the ammeter and wiring are all good and in place and the rectifier is good, the AC alternator wiring may be bad. It (its 2 wires) MUST be a contunuous circuit to work which you can test with an ohmmeter and neither can be shorted to frame ground either. I think they (alternators) put out somewhere around 24 to 28 volts AC at RPM, then after rectified (2 AC in 1 DC out) its around 13 volts DC.
Be sure all wires are in place and theres no shorts, there should be 12 volts on BOTH ammeter terminals to work or theres a bad or missing wire or bad ammeter. Its been my experience failures are usually in a bad or shorted wire or the rectifier goes bad then the alternator wiring may become open or shorted. NOTE the battery has to be good and capable of acceptign a charge also as those systems dont put out much current.
John T
Bob
11-07-2004 09:12:00
 Re: 160 lawn tractor won't charge the battery in reply to John T, 11-07-2004 07:35:38
The circuit from the output of the voltage regulator to the battery often passes through the ignition switch on these LGT's.
A bad switch or corrosion on the terminals at the back of the switch can cause a no-charge problem.
