White smoke is more likely from moisture. Might be from condensation from when the engine wasn't warmed up the previous run. Black soot and smoke comes from excess fuel. I've found multiple sources for that on my 4020. 1. Leaking float needle and seat. It wears from vibration and is the prime suspect raising the gas level in the float bowl leading to running rich. 2. Leaking float. 3. Choke doesn't open all the way. On my 4020 that was caused by the choke cable sheath not being anchored near the carburetor. 4. Dirty air cleaner and/or intake pipes. Birds, bees, mud daubers, and wasps also like intake pipes for nest protection. 5. Top of the precleaner squeezed down. It should dome up, not down. 6. Carburetor mixture screws set rich. 7. Not enough manifold heat. My 4020 manual calls for heat up to 70 or higher when not loaded heavily. That long manifold takes a lot of heat to keep from condensing fuel on its way to the end cylinders. Gerald J.
