Connecting a trickle charger with 2 batteries
Mike T. Deere
11-06-2004 17:19:11
Hello
I was wondering if anybody could give me some feed back. I just ordered a trickle battery charger (12 volt) which I have not yet received. I am wondering about proper connection. This is going on a tractor with 2 12 volt batteries. With winter soon approaching I thought it would be a good idea to keep the batteries charged up for when we get the big snow storm. Do I just connect the clamp to one of the positive terminals and just ground the negative to the frame of the tractor? Does it matter which battery?
John T
11-07-2004 07:09:10
 Re: Connecting a trickle charger with 2 batteries in reply to Mike T. Deere, 11-06-2004 17:19:11
Mike, a "12 volt" charger can charge a 12 volt battery(s) (either one or two or even more if in parallel) SO LONG AS IN PROPER POLARITY, i.e. pos to pos and neg to neg. If you have a dual 12 volt in series 24 volt system (like on 4000 series diesels etc or even 730) then with only one 12 volt charger, you have to charge each individually one at a time, again at proper polarity, pos to pos neg to neg, and you dont have to disconnect either battery from the tractor. If you wanted to charge the two 12 volt batterys in series at the same time, you would need to do what the Generator does, i.e. be above 24 volts (a 24 volt system charger) and connected across the series of both batterys, still at proper polarity.
If you have a small 12 volt trickle charger and a dual battery series 24 volt system, charge the one at a time for approximate equal times.
Good Luck n God Bless
John T
F-I-T
11-06-2004 17:26:27
Mike:
Well, that depends. If the batteries are wired parallel (POS to POS and NEG to NEG), then yes, connect your charger Red to either POS terminal, and black to either NEG terminal. Pos ground or negative ground does not matter. Battery polarity is what you're following.
Now, if you have a 24 volt system so that the batteries are connected in series (+ to - to + to -), then you either have the incorrect charger, or you will have to disconnect some cables so that you can trickle charge them during down time, then reconnect the cables for series operation when you are ready to plow.
Frank
Bob
11-06-2004 17:58:50
 Re: Connecting a trickle charger with 2 batteries in reply to F-I-T, 11-06-2004 17:26:27
If he has series-connected 12 Volt batteries in a 24 Volt system, he can connect a 12 Volt trickle charger to EACH battery, matching the charger lead polarites to the battery post polarities and no disconnect and reconnect are necessary.
I have a Deere 4020 with a 24 Volt system set up like this, with 2 12 Volt trickle chargers, to keep the batteries up for cold winter starts.
I plug the tank heater in an hour or two ahead of time, and it will start at ANY temperature.
chip
11-06-2004 19:23:06
 Re: Connecting a trickle charger with 2 batteries in reply to Bob, 11-06-2004 17:58:50
4020--- in cold weather did you ever put a plastic bag over the Right side screen of the radiator to stop cold air from getting to the HYDRAULIC OIL cooler? This helps the oil warm up which is easier on the pump. Warm oil is easier to pump than cold oil!!
F-I-T
11-06-2004 19:16:46
Sure, that will work. He would just need a second charger. What kind of trickle charger(s) do you use? I have ones called "Battery Tender", and they work very well. I have one for 6 volt batteries, too, and it really keeps them charged right to the top.
Pete/ME
11-07-2004 03:18:38
 Re: Connecting a trickle charger with 2 batteries in reply to F-I-T, 11-06-2004 19:16:46
Don't know anything about it, but two weeks ago at my JD dealership there was a new trickle charging system on display. Might want to check it out.
