90W oil
Big Yarber
11-06-2004 08:52:48
does anyone know where i can get some 90W oil for the rear end of a 1952 John Deere B. And what the cost would be for a 5- Gallon Bucket?
Henry J
11-07-2004 05:42:17
 Re: 90W oil in reply to Big Yarber, 11-06-2004 08:52:48
Big
Just thought I would stir the pot for grins.
Sometime back in the early 50's when I was a pup my dad bought a 47 2N Ford. This seems to be back when we worried about if the chickens were gonna lay enough egggs for breakfast. I remember that stinky slimy GL5 stuff that we topped the trans off thru the years - and it ain't been changed to this day. The ole gray beast is semi retired but my brother still uses it. Hmm, wonder what that stuff looks like in the tranny lol. The dip stick sure was fat when you pulled it out of that goop to check it.
Now, as I foggily recall, when it comes to hypoid gears such as in a ring and pinion, today and for quite a while back, gl 5 is recommended. It seemed that most were talking about the JD's that rock back and forth when idling as opposed to the Dubuques that bounce up and down and have a differential in them. I feel comfortable with 80-140 gl 5 in my 420 as I check it and feel it and smell it about once a year and would change it if it got any kind of funky.
gusc
11-06-2004 21:09:14
GL-1 is what used to be called Mineral Oil and has minimum if any additives. GL-5 is used where XP or Extreme Pressure lube is called for.
The best one for 90W applications is 80W-140 which works better under varying temperatures. I use it in all my old tractors and trucks.
andy b.
11-06-2004 20:51:29
i think it is the zinc in GL-5 that attacks the brass and bronze in the old trannies. is there a CarQuest near you? they can order in 5 gal buckets of GL-1 90wt. that's where i get it from and it is about $20 or so.
andy b.
Bob
11-06-2004 20:56:58
 Re: 90W oil in reply to andy b., 11-06-2004 20:51:29
Andy B.,
There IS zinc in many brass or bronze alloys.
CPeter
11-06-2004 14:10:04
You may want to GL-1 in that application. It is available, but yo have to look. the additives in GL-4 and GL-5 can corrode the soft metal used in some of the older transmissions. I get GL-1 90 and 140 wt from my local auto parts store. It is Amalie brand.
CPeter
gathje
11-06-2004 20:00:37
 Re: 90W oil in reply to CPeter, 11-06-2004 14:10:04
First I heard of the GL5 being bad for a transmission.Changed old dirty oil to Fleet Farm 80w90 in my 50 and 60 jd.That cost enough so I hate to do it over.What does it hurt ,the gears or the shafts or bearings,brass,or what?Does it actualy corrode things? Thanks for the advice in advance.
buickanddeere
11-06-2004 21:18:36
 Re: 90W oil in reply to gathje, 11-06-2004 20:00:37
It's sulphur which is used as a high pressure wear additive in GL5. Makes the oil stink and turn to sulphuric acid if exposed to water. Early gear drives used what was prety much heavy crude oil or some pretty thick stuff from the bottom of the distilation towers. This had a teaspoon or two of yellow sulphur power added to put a hardened "skin" on the metal gear surfaces. Marine gear drive GL4 ( If memory serves?) lube uses additives that don't turn acidic when exposed to water and oxygen. Works fine if GL1 can't be located.
Bob
11-06-2004 20:15:13
The warning is about deterioration of brass parts (thrust washers) over a LONG PERIOD of time by the additives in the GL-5.
I seem to recall reading that one of the major oil companies states in their spec sheet that their GL-5 is OK in that respect, but I can't recall which one or where I read it.
CPeter
11-06-2004 20:12:41
As told to me by Clooney and others, the sulfur in the additives mixes with the moisture to form sulfuric acid which corrodes the basss and bronze bushings and bearings.
CPeter
gathje
11-07-2004 19:04:14
 Re: 90W oil in reply to CPeter, 11-06-2004 20:12:41
Thanks for all the come backs.Sounds like a guy better at least watch for moisture in the oil.Maybe change to GL1 sometime in the future.
buickanddeere
11-06-2004 16:39:45
Marine grade gear oil is OK if GL1 can't be found. It's additives are less corrosive if water gets mixed with the oil.
dbwillia
11-06-2004 12:25:30
Wal-mart sells 90 wt oil for around $23.00 for a five gallon bucket.
Lee C
11-06-2004 11:47:56
Any auto parts store should carry 90 weight oil. Its the same stuff used in automotive differentails
