4010 Voltage Regulator
Lee C
11-06-2004 08:43:16
I"ve fixed the starter problem, I"ve replaced the field windings in the generator, now it appears that the charging system is still not working. I know, replace the regulator. But before I spend the $44+, are there some simple checks That I can do to make sure it is the regulator?
Chip
11-06-2004 19:11:38
 Re: 4010 Voltage Regulator in reply to Lee C, 11-06-2004 08:43:16
One terminal on the generator actually generates NEGATIVE 12 volts the other generates POSITIVE 12 volts. The generator doesn't make 24 volts. Put a voltmeter on the generator and check it that way or take it apart and look at it, You'll notice the Negative terminal has plastic to prevent it from touching or grounding. Negative generator wire feeds through the regulator then to the KEY switch then to the starter Negative post. Positive generator post feeds through the regulator then to the KEY then to the starter Positive post. At the key is where the wire to the generator LIGHT is plugged in. Lights are plugged in to Key so that some of the lights run by the Negative power and some are run by the POSITIVE power. If too many lights are hooked to the one side of the generator the lights will go dim. Because only one winding in the generator is doing all the work. I believe that the fuel guage is powered by Negative power (positive ground) MAKE SURE the small wire on the Left battery that goes from the negative post of the battery to the frame of the tractor is connected.
Bob
11-06-2004 20:28:34
 Re: 4010 Voltage Regulator in reply to Chip, 11-06-2004 19:11:38
You are wrong, Chip. The generator has no center tap, and the innards have NO connection to the generator case. From the generator's point of view, the output of the armature is carried to the A1 and A2 terminals by the brushes and the output of the generator IS 24 Volts, or actually around 28 Volts, as measured between the A1 and A2 terminals.
Simply put, the generator charges at the full system voltage, and the electrical LOADS (batteries, lights, and instruments) are split into 2 - 12 Volt loads, 1 positive ground 12 Volt, and 1 negative ground 12 Volt.
There is NO 12 Volt negative winding and NO 12 Volt positive winding in the generator. Just one ARMATURE that outputs 24 (28) Volts through the 2 brushes to the A1 and A2 terminals.
All that is needed to check the generator output is to accurately measure across those two terminals for 28 Volts (or whatever the exact spec is).
If the generator is charging at the rated output voltage, and the voltage across one battery is significantly higher or lower than the voltage across the other battery (assuming no loads such as light are on at that time), a defective battery is indicated.
That's why it's good practice to replace both batteries at the same time, with matching batteries.
Chip
11-11-2004 18:29:15
 Re: 4010 Voltage Regulator in reply to Bob, 11-06-2004 20:28:34
My mistake Bob,the generator has 24V stamped on it. so if I understand correctly the wire that grounds the left battery neg post to the frame is how 12volts is achieved for accessories.
Lee C
11-06-2004 10:11:10
I have not checked between A1 &A2,but I did check across the batteries and it indicated 23V.
I did polarize the generator by momentarily jumping the Batt terminal and the Gen terminal as per the manual. My version of the full field test showed generator is operating. I Call it my version because I didn't do it quite to the book. I disconnected the field wire and A1. Jumped Terminal F to A2 and connected a voltmeter between A1 & A2. This was all per the book. I didn't have an ammeter or a way to accurately measure RPM's. So I just started the engine and increased RPM's briefly. I saw 32 volts momentarily.
Bob
11-06-2004 10:29:10
 Re: 4010 Voltage Regulator in reply to Lee C, 11-06-2004 10:11:10
It sounds like you've been thorough with what you've done, Lee. Providing your wiring connections are correct, it sure looks like the regulator is bad.
Have you looked at the points inside the regulator?
Disconnect the batteries. Remove the regulator cover. There will be 3 relays. The one with the heaviest points is the "cutout relay".
Of the remaining 2, the relay wound with fine wire is the "voltage regulator", and the one wound with heavier wire is the "current regulator".
At startup, the N/C contacts of both relays are in series with the generator field, and if either set is not making contact, there will be no charge. Cleaning those contacts may make the regulator work, at least for a while.
The heavy cutout contacts may be silver plated, and excessive cleaning there may remove what's left of the silver, and case the contacts to stick, draining the battery, and possibly burning out the generator.
Lee C
11-06-2004 10:35:06
 Re: 4010 Voltage Regulator in reply to Bob, 11-06-2004 10:29:10
I have looked at the points and they appear to okay. Are the cut out relay points suppose to open or closed when engine is running? Mine are open. I should know all of this but it has been 30 years since my days in auto shop and I am quite rusty with this old stuff.
Bob
11-06-2004 10:38:22
 Re: 4010 Voltage Regulator in reply to Lee C, 11-06-2004 10:35:06
Upper voltage and current regulator points will be CLOSED until battery voltage comes up, or charge current is excessive.
Cutout relay points will be "open" to prevent discharge of battery into the generator, and CLOSE as soon as the generator output voltage comes up to a pre-determined level.
Do the cutout points pull closed when you "full-field" the generator?
Lee C
11-06-2004 10:51:45
 Re: 4010 Voltage Regulator in reply to Bob, 11-06-2004 10:38:22
The cut-out points remained open, but most of the regulator is out of the picture the way I did full field. I did attempt to check point gaps per the book, but the procedure didn't make any sense
Bob
11-06-2004 09:05:35
Have you actually checked the generator voltage across the A1 and A2 terminals with a voltmeter, or are you going by the "idiot light" being on all the time?
Have you polarized the generator? That is simple on 12 Volt systems, but on the Deere 24 Volt split system, you have to be SURE of what you're doing! (I can't help you with detailed instructions on that at the moment, as I'm away from my shop and books for the weekend.)
If you HAVE polarized it, and it isn't charging, you need to FULL FIELD the generator and see if it charges then.
Again that is simple on a normal system, but, again, with this system, it's a bit more detailed, and you need EXACT instructions, or there's gonna be smoke!
(Full-fielding is the same as what a fuctioning regulator does when maximum charge is needed, and when you do this with a jumper wire, your verifying that the generator is working, and localizing the problem to the regulator.)
