4320, not charging need input!!!
Luke Rhonemus
11-05-2004 19:01:01
Hello, I have a 4320 that I recently has not been charging. Tested the alternator and was charging except for when it was under a load. Regulator an alt. was bad and replaced it with a new one, now tested fine. But....alternator light continues to stay on and does not go out. One battery had a dead cell and starter has a new solenoid. Was wondering if it is still a charging problem or if the groggy turn over could be a bad ground cable? Is there a fuse somewhere that could be blown? Any info would be greatly appreciated. (Tractor does fire right up with a booster on it)
buickanddeere
11-05-2004 19:16:13
 Re: 4320, not charging need input!!! in reply to Luke Rhonemus, 11-05-2004 19:01:01
Sounds like at least one shorted diode in the alternator stator output. That's why the output current is way low even though it may make rated voltage at low loads. When servicing an alternator it's often less trouble to put all new internals rather than replace the one part that had failed.
