manifold stud leaking
Betts
11-05-2004 17:29:20
I just got my 34 A running after a complete overhaul and the manifold stud that goes into the head and into the coolant is leaking. I did put the white liquid teflon on it when I installed it but it didn't seem to do any good. should I try some type of stop leak (what brand is best) or should I take the manifold back off and try some other type of sealant on the threads (also which is best). Or will it stop leaking in time after if corrodes. thanks Betts
Weirsdale George
11-06-2004 02:11:50
 Re: manifold stud leaking in reply to Betts, 11-05-2004 17:29:20
Permatex #2 works good as a thread sealant.
Garland
11-05-2004 23:17:17
Betts I've had them to leak and they will eventually seal off might take awhile but they will seal off. I've put a plumbers pipe dope like they use on black iron pipe that works good,I'll tell you something that I've never tried but beleive it might work,take stud out and put some soilder on the threads and reinstall the stud like I said I've not tried this method as of yet. Good luck Gman
