JD 60 Outside Gear on brake drum
MGTPa
11-05-2004 17:04:16
I have 1953 JD 60. On the outside of both brake pulley drums there is a 9 tooth gear, 4 inches diameter, mounted on the end of the brake drum shaft. Seems that some sort of chain would go over the 9 tooth gear to run some piece of equipment powering it when the brake drum turns when the tractor is moving. It is painted JD green and is original to the tractor and was never used for whatever its intended purpose was. Any ideas? Sorry no pics. Thanks. MGTPa.
Phil Hunsberger
10-02-2006 23:24:10
 Re: JD 60 Outside Gear on brake drum in reply to MGTPa, 11-05-2004 17:04:16
Hello. Just read your talk on the brake drum gear while I was looking for talk on sidedressing attachments. Your guy probably answered it right, but I will add that I just bought a new 4row sidedressingt attachment that was never sold by a dealer, made in probably 1958 to 1960. They are called 401 and 402 attachments. My kit has the drive sprockets in it like you are asking about. They drive a chain to a slip clutch on each side of the tractor. The boxes shut off with the cultivator lifting up and a linkage closes the doors on the bottom of the boxes where each row has 2 tubes dropping it behind the shovels. My sprockets are new, but I wonder if you want to sell yours? Does your tractor have anything like a lever clamped to the square rockshaft stub that lifts the cultivators. My parts book shows something that goes there and I'm uncertain how it works since it is called something of a lift linkeage. If it does, I would send you a picture of the parts page showing it. Thanks, Phil
RalphinWI
11-06-2004 08:00:05
In foggy reaches of my mind I remeber seeing illustrations of that gear and its use, but it escapes me now. A guess would be the side-dressing attachment, which had a short lifetime. After seeing what 3-12-12 did to fertilizer boxes on planters, farmers decided that they didn't want to give the same treatment to the cultivator or tractor. I also seem to remember that those boxes were fairly high and in those day fertilizer came in 80# bags.
MGTPa
11-06-2004 13:05:40
 Re: JD 60 Outside Gear on brake drum in reply to RalphinWI, 11-06-2004 08:00:05
Thanks. That makes sense, to use that brake drum gear to run a fertilizer attachment. Maybe someone else has seen pictures in an old JD implement manual of another use of these brake drum outside 9 tooth gears on a JD 60?
