BLOCK
ROUGH ENOUGH
11-04-2004 14:59:33
LOOKING FOR A GOOD BLOCK FOR LATE MODEL A ALSO IS A 60 BLOCK THE SAME AS THE A
G-MAN
11-04-2004 15:34:52
 Re: BLOCK in reply to ROUGH ENOUGH, 11-04-2004 14:59:33
Yes, "A"s from 477000 and up and "AR"s and "AO"s from 272000 and up use the same AA5052R block as the "60". Deere still stocked that block until the early 90s, so you could probably find a NOS one. It also shouldn't be hard to find a decent used on, and I believe Abilene Machine might offer rebored block kits.
Mike Aylward
11-04-2004 16:47:55
 Re: BLOCK in reply to G-MAN, 11-04-2004 15:34:52
G-MAN, the serial number break for the late A that shares the 60 block is 648,000 and up. The late A"s originally used the A3703R (casting number) block which was substituted to the A4320R block which was used with the 60"s. The only difference between the two blocks is the A4320R block has two bolt holes in the front bottom corners that use bolts that come up through the frame and into the block. The earlier blocks are different in that they use a different mounting pattern. Mike
