Does anyone know if this could be true???
nfg
11-04-2004 10:33:23
The other day I was at a farm looking at a set of plows that where for sale. The farmer started showing me his tractors.... he had a 4055,a old JD 4000,and a 2755 that he swears is putting out 92HP. Could this be true ???? I thought a 2755 was only 75 HP. He claimed that he had a old 2840 that he bought new and when the 55's came out that he liked the looks of them and he bought a 4WD 2755 off his local dealer to replace the 2840. He claimed that a salesman from the dealer stop by a few months after he bought the tractor and asked him how he liked it. He told the salesman that he loved it ,but he thought his old 2840 had a little more HP on the PTO. The farmer told me that the dealer took the 2755 back to "tune it up" for him.... He claims that when they brought it back to him they told him it was putting out 92 HP. I saw the the tractor run myself and let me tell you when he opened it up jet black smoke came out off it. Does anyone think this could be a true story ??? Myself I don't think you could turn a 2755 up that much.
Gerry_Luzerne_MI
11-23-2004 06:26:59
 Re: Does anyone know if this could be true??? in reply to nfg, 11-04-2004 10:33:23
Test ... To reserve name
Loren-MN
11-05-2004 10:06:26
Anything is almost possible. Dad had a 1960 730 gasser (rated at about 54 HP) putting out 72 HP on the dyno. Smoked like a diesel, manifold and muffler were red when plowing at night, ate gas like crazy, but sure would pull. Guy who owns it now uses it in the tractor pull circuit and is a constant winner. Tried to buy it back, but he won"t sell.
gbpw
11-05-2004 00:10:57
In Europe, the 2850 SA (3.9L turbo) was factory rated at about 80 hp, equal to 3050/2955.
The standard 2850 (75 hp) was comparable to US 2755. So I suppose you can get bit more out of it, but putting it to 90 hp won't be efficient.
Btw can such a 3.9T be changed for a 4.5T? this might give the extra hp (upto 100-105 or so).
730-LP
11-04-2004 20:26:39
I would say yes that it's very possible I have two 2355's[factory rated 55hp] when one was bought new it was put on the dyno at the dealer and was 70hp.I have had both on my dyno and they both show 68hp.both tractor have around 3500 hrs.
jd 2355
11-05-2004 05:02:49
 Re: Does anyone know if this could be true??? in reply to 730-LP, 11-04-2004 20:26:39
Hi, I also have a 2355 that dynos 70 hp. I think 90 hp. is a pretty normal figure for the 2755's. My tractor has over 5000 hrs, and I never see any black smoke.
buickandeere
11-05-2004 10:14:49
 Re: Does anyone know if this could be true??? in reply to jd 2355, 11-05-2004 05:02:49
Those 2355's were rated for 56HP PTO but they tended to do a little better. 68 to 70HP has to be into the area where black smoke is appearing. And smoke is unburned fuel going up the stack.
WTW
11-04-2004 10:40:08
Absolutely, The 2755 with a 4.5 Liter engine was also equipped with a turbo. All you have to due is alter the fuel delivery to make it happen. It will do it easy. DW
buickanddeere
11-04-2004 16:14:55
 Re: Does anyone know if this could be true??? in reply to WTW, 11-04-2004 10:40:08
239 cubic inches and a turbo with no intercooler will run around 75HP ideal. That's .30 to .33 HP per cu". A natural aspirated runs about .25 HP per cu". Turbo intercooled .40 to .50 HP per cu" is about it. This with old generation engines before four valve heads and electronic fuel injection etc. Getting .385HP/ cu" from that 239 is looking for trouble and putting unburned fuel up the stack. She's not moving enough fresh air into the engine and getting the exhaust out. I assume this dealer also offers full warranty on the engine and drive train? Those sleeves are going to leak some day if the pistons don't score them first. These "bright lights" are likely pulling some load too big for the tractor and have it over ballasted and geared down while lugging the engine. How long do they think it's going to last? Then they will be whining about their cheap Deere tractor that fell apart.
