I'll start with the single brakes: All Ds were made with a "service brake" or parking brake. The early type (up to #130699) was a brake band around a drum inside the transmission, and controlled with a lever on the left side of the transmission. A later type (#130700 and after) moved the brake drum/band to the outside (left side bottom) of the transmission, and it was controlled with a foot pedal on the right side of the platform. The wheel brakes: Wheel brakes (with brakes inside each wheel) were introduced in February 1936 at #126415 (with a handful before hand). They were made for the DI (industrial) but also used on the normal Ds (not often on unstyled Ds, but more common on styled Ds) At first the wheel brakes were only controlled by a lever on the left side of the platform. You could only lock both wheels at the same time (no indiviual control). Sometime later (I don't know when) there were indivdual pedals introduced so you could use one brake, or the other. The lever was still there to lock both for parking. When equipped with wheel brakes, the tractor still had the service brake. Hope this didn't get too confusing! Feel free to email me, I can dig up some photos if needed. Brandon My Industrial John Deere website John Deere Diesels The LaGrange Engine Club
