B engine rebuild
37G
02-08-2004 14:41:41
Ok. Got everything tore apart. Since i have it all apart i paln on rebuilding it but dont want to do anything that is not neccesary. How do i know if i should replace the main bearing....or should i just replace them and be done with it. The cylinders look decent (not pitted and pretty clean) But with the rings i plan on just replacing the rings so i dont worry bout them. Where do i buy bearings and rings for this 35 B. Can i still pick these up at John Deere and about how much will it set me back? thanks
old
02-08-2004 17:47:06
 Re: B engine rebuild in reply to 37G, 02-08-2004 14:41:41
JD should still have them ring part # B49200, sorry I don't seem to be able to find bearing #. By the way that # came from a 1935 owners manual for a B
Karen
02-08-2004 16:43:16
Send me an email and I can give you the name of a place to get parts. You'll need the serial number to order.
