4020 rebuild, want more power
JD 4020 3020
11-02-2004 20:32:54
I have a '64 4020 diesel. It needs a overhaul. Once i am doing this I want it done right. The injector pump is not an issue, But I want to make sure i don't miss something to change to give this thing as much powere as I can reasonably afford. I plan on getting the Predator kit, not just for the power, but cold starts as well. It has the big injectors, and I have been told to change the tips to the 5 hole style used in the 4520 or 4620. I have heard that a 4240 or 4440 cam will help, as well as a newer intake manifold. The problem is that I don't have a reputable source of this information and I am not exactly sure if I should try these things or not. What have some of you tried that seems to work well? What would you advise me to stay away from?
JD 4020 3020
11-04-2004 16:43:18
 Re: 4020 rebuild, want more power in reply to JD 4020 3020, 11-02-2004 20:32:54
Just to let you know, this 4020 has at least 7000 hours on it and currently puts out 105 horsepower, but it has a blown piston. I am not worried about the reliability of the engine because it has allready prooven itself once, and after 7000 hours its still going. I just wanted some input on some things that I will likely have to replace anyways once it is apart. And, no I will not trade this tractor for a bigger one. I don't need the extra power, but if it can be had why not do it.
Indydirtfarmer
11-03-2004 05:17:23
The '64 4020 was near it's limit on power AND reliability. In 1966, then agian in 1969, updates on the lubrication system and cooling system made them a little more durable. You MIGHT squeeze out another 10% on the horsepower, but you would do so at the risk of drastically shortening the life expectancy of the engine. If you're like most of us, you won't want to sink a ton of cash into a rebuild, just to have it blow up a year or two down the line. It is possible, and in fact has been done MANY times, to get more power out of older 4020's. But just remember, you're dealing with a 40 year old tractor. You don't want to see what parts have a 41 year life expectancy....
I like the idea of trading it on a 4230/4430 or a 4240/4440. They are MUCH better tractors. (Especially the 40 series) You will get more power, a much more durable tractor, and you won't be stretching the limits of their intended use.
My uncle was all into "hopping up" 4020's back in the 60's and 70's. He would squeeze 125 to 140 HP out of them. They would burn pistons with amasing regularity. He was into "turbo kits". I still have dads 4020 that he bought new in '71. It's still at "stock HP". Uncle Jim gave up on his "plans" and bought a 6030....He never needed more power after that...
Leland
11-03-2004 21:55:24
 Re: 4020 rebuild, want more power in reply to Indydirtfarmer, 11-03-2004 05:17:23
Indy I have watched this being done to a 4020 he put a huge turbo a 44 qt oilpan bigger injectors and played with pump and he claimed to get 250-300 hp out of those old things. but I belive him he's won the nationals in louisville a few times.
Indydirtfarmer
11-04-2004 03:14:38
 Re: 4020 rebuild, want more power in reply to Leland , 11-03-2004 21:55:24
Huge difference between a 15 second pass down a pulling track and 12 hours in the field under a blazing sun, and a cloud of dust.
I've seen several 4020's turned up to 105-115 hp with no turbo. Got a neighbor with a turbo-ed 4020 that's been around for 25 years in that configuration. They don't all expire in short order. It's just more likely they'll give up prematurely when you go messing with things.
"Field modifications" and their "accidental engineering", are no match for the thousands of hours, and millions of dollars worth of engineering done by John Deere. There are MANY good shops around the country, with many talented mechanics doing the modifications. Some even have great track records with their engine build-ups. My point is, you greatly increase the likelyhood of pushing things beyond the safe limits when you go to doing all of this with what is NOW a 40 year old tractor engine. Also take into consideration that there is a huge difference between an engine re-build in a FULL-TIME PROFESSIONAL TRACTOR ENGINE SHOP, and someone in their barn, trying to take a mix-match of parts and put together a "one-time in a lifetime" high performance diesel. JMHO John
Leland
11-04-2004 05:57:38
 Re: 4020 rebuild, want more power in reply to Indydirtfarmer, 11-04-2004 03:14:38
Sorry for that failure to totaly explain these were every day 4020s used for field work. This guy is a self taught J.D wrench spinner had worked for dealers for years until going on his own.He has a good working realation ship with JD in Moline. He has solved a few of there problems that drove engineers nuts like why early 4430 rear ends kept going out. But I have watched him do a lot of things that they said could not be done and have good sucess. Now he really wants to do mostly pump and turbo work and build custom parts for pullers.I think this guy would really impress you Indy.
jdemaris
11-03-2004 15:08:17
We used to turn up a lot of 4020s at owner's request and the engines didn't suffer from it (as far as I can tell). My neighbor bought two new 4020s back in 69. One was an awful cold starter and other was always a great starter - down to 10 degrees F with no block heater or ether. He finally got rid of the bad starter after many failed attempts to improve its starting. He still has the other one. I turned it up to 106 horse on the dyno back in the 70s. Anything beyond that point resulted in excess smoke under load. It's been rebuilt three times and averaged 10,000 hours between rebuilds. Last rebuild shouldn't even count because he broke a radiator hose, ran it low on coolant, and melted one piston. Suprisingly, the others showed very little wear. We also turned up a lot of 2520s with no apparent bad effects. As far as turbo kits go, I've never installed one. From what I've seen and read, an engine should be designed for it, not just have it added. A turbo increases the effective compression ratio, and subsequently, many if not most factory turbo engines have lower natural compression ratios to compensate for what happens during boost. So, it seems adding a turbo to an engine not designed for it could or would yield great horsepower gains and a shortened life. But, I don't profess to be an engineer. I DO recall years back when turbos were called "altitude compensators." But, at the time, Deere's remedy for high altitude was using "high altitude" pistons. I installed a set in a gas 2020 and used the tractor in a low altitude setting - thinking it would add power. It was AWFUL. Knocked all the time no matter how I timed it unless I used high test in it.
G-MAN
11-03-2004 15:47:05
 Re: 4020 rebuild, want more power in reply to jdemaris, 11-03-2004 15:08:17
Those are all good observations and points. The greatest problem with turboing some non-turboed engines such as in a 4020 is that there are no cooling jets to direct a cooling spray of engine oil at the bottom of the piston. I've seen M&W'ed 4020s at 140-150 horsepower that seemed to live fine, but I sure wouldn't push one much further. Of course a full M&W kit would compensate some by beefing up the cooling and lube systems. Another factor is how often the full horsepower is actually used. Until you put a full load on the engine and pull it down to rated RPM, it's not making full power and is not stressing the components fully. As you mentioned, 110 horsepower for a good stock 4020 with no turbo is probably the limit, as you run into a situation of not getting enough air to make more power without overfueling.
buickanddeere
11-03-2004 03:40:27
Trading for a 4620 or 4430 etc in good shape will be the cheapest and most satisfactory solution.
