Bebuild on 1944 hand start B
Wayne Johnson
11-02-2004 13:13:34
I have been told I can bore my early styled B to accept late styled pistons. My conceren is how will this affect compression as I want to keep it a hand start. Thanks Wayne
WTW
11-02-2004 13:31:29
 Re: Bebuild on 1944 hand start B in reply to Wayne Johnson, 11-02-2004 13:13:34
Wayne, You will still be able to start it. With the aid of compression releases and proper tuning it will be easy. You may get up to around 7.5 to 1 compression depending on head work. I start my modified puller with a Power-Block and Stroker crank by hand. It is at 10 to 1 ratio and has no compression releases. It's not easy but can be done if you are determined to do it. At least your tractor will have finger grips in the flywheel where mine does not. It will really run nice burning regular octane gas with the late piston setup. Good Luck, DW
